Old 05-25-2006, 10:40 AM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Looking at buying a Stealth.
I like my Sebring and all, but the fact is, it's slow. So I'm going to sell it and buy a TT Stealth for my daily driver. I've read through the FAQ and I have just a few questions.
1. How hard is it to change out the lash adjusters? I know that if I'm going to buy a Stealth then I have no choice as I'm going to have the lifter tick problem. Also, if I do it myself, how much am I looking at?
2. I prefer the first gen and I like the styling more. However, I am curious about dirveability and performance pros and cons with the five speed vs. the six speed.
3. Lastly, know anyone that wants a 98' Sebring?
Old 05-25-2006, 12:50 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Looking at buying a Stealth.
1. i don't know of anyone on here that has changed their lifters yet. i know BlinkRA182 has purchased the 99 style lifters, but has yet to swap in the new ones. if you are really worried about lifter tick...don't. it just comes and goes. if it does come, do an oil change, and if that doesn't fix it and its unbearable (that is you can actually hear it over your spooling turbos and loud engine), then get the 99 lifters.
as for install, i've ran across some helpful threads that can guide you in the right direction:
here's a write-up by Jeff Lucius--> http://www.stealth316.com/misc/insta...ew_lifters.doc
valve spring compressor tool (make your own)--> http://www.3si.org/forum/showthread....0&page=1&pp=10
valve spring compressor to purchase--> http://www.jcwhitney.com/webapp/wcs/...atalogId=10101
more info--> http://www.automotiveforums.com/vbul...ht=lifter+tick
info--> http://www.team3s.com/FAQliftertick.htm
and in the FAQ thread, i've listed some resources to purchase lifters for around 220-300 bucks.
2. 5spd vs. 6spd? as far as driveability is concerned, they're both fine. yes, the 6spd will give you a tad better gas mileage on the highway. if your looking into making big power and launching your car repeatedly from 6k rpm, then the 6spd has a stronger transfercase. however, the 5spd has better gearing for the 1/4 mile. but these differences aren't noticeable unless you drive the crap out of it and are making around 500awhp. so for your daily driver, the 1st gen 5spd would be fine.
3. '98 sebring? i'll pass. i'll keep my 3000.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 05-25-2006, 01:41 PM
Polygon's Avatar
The Red Baron
I'm not too worried about the lifter tick. My project car is a Turbo II LeBaron so I'm used to it. I was just under the impression it was common to change the lash adjusters to the newer ones. Also, once the LeBaron is done I will make this Stealth my project and start making it faster and I may get it up to 500AWHP. However, I'm not concerned with the 1/4 mile. I like the twisties.
Thanks for the info.
Old 05-25-2006, 01:44 PM
AutostradaVR4 AutostradaVR4 is offline
changing the lifters isnt that hard...i just havnt gotten around to it because; 1, i cant work on it when the weathers bad. and 2, when the weathers nice, i wanna drive it, not work on it lol. Plan for the car being down for a day though, maybe less if you have a friend and know what your doing. As for price, i got my set for $114 shipped from a group-buy on 3si. Like Linebckr said though, i wouldnt worry about it unless its ticking really bad. Just keep up on your oil changes. (mines not ticking at all...im just anal )
As for your second question, Linebckr nailed it. If you like the first gen style AND plan on making big horsepower, go with a 1993, as they upgraded some internals and went to a 4-bolt main for 93 and up twin turbos. But that only matters if you plan on making 500+ horses.
As for the Sebring...i need a new winter beater, but im not driving to Utah to get it lol. Good luck with the sale.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 05-25-2006, 06:30 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
hey, poly want a stealth? lol
honestly you might not even have lifter tick, its a hit and miss with these cars
i have it, but the only time it occurs is when my oil is low, wich i now like the tick as it gives me warning
as for the twisties, well we dont have to tell ya, your gonna wanna do some weight reduction
but it handles fairly well...i'm sure you've done your research and already know most of this..good luck with your search
when testing out your stealths, check for gear grinding
Old 05-25-2006, 09:19 PM
Polygon's Avatar
The Red Baron
Thanks for the tips guys.
Yeah, I knew about the weight problem, but that's alright. I had a friend with a 92' TT and it was heavily modified under the hood with some light suspension work and I had trouble breaking it loose doing some canyon carving. Too bad he sold it to some guy for $8,500. I would have bought it!!
Old 05-25-2006, 11:09 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Cool. Poly wants a Stealth. Are you strictly looking for a Stealth or possibly a 3kgt too? Well, best of luck too.
Old 05-26-2006, 07:15 AM
Zeiss's Avatar
Zeiss Zeiss is offline
Stealth > 3000gt
Bye V8...
Old 05-26-2006, 09:14 AM
Polygon's Avatar
The Red Baron
Originally Posted by Zeiss
Stealth > 3000gt
Have to agree. I prefer the styling of the Stealth over the 3000GT, plus I'm not paying $3,000 - $5,000 more for the same thing.
Old 05-26-2006, 11:06 AM
VR43000GT's Avatar
HA! You just want to still have a car that when people see it they think its still a mopar. For shame! Good day Polygon..........I SAID GOOD DAY!
But seriously, I have seen Stealths that were going for 1/2 of what my car was in similar condition. That is because 3kgt's hold their value much better than Stealths do. So depending on how long your going to keep the car, I would think the 3kgt would be your better bet if you were planning on having it for a while.
Old 05-26-2006, 12:06 PM
Polygon's Avatar
The Red Baron
Nah, I tell people that my Sebring is a Mitsu. I don't care. However, I know that it won't hold it's value but I don't buy project cars to sell them. The LeBaron and whatever Stealth I buy will never be sold.
Old 05-27-2006, 08:26 AM
Zeiss's Avatar
Stealths value will go back up, it will take time though..not to mention they are quite a bit rarer then 3000gts
Bye V8...
Old 05-27-2006, 11:50 AM
Linebckr49's Avatar
but the 3000 is an import, so its value will always be greater than the Stealth, a domestic. ya, ppl are stupid and it should be based on rarity, but if it does happen like you said, it won't be for quite a while.
93 3000GT base
Old 05-27-2006, 12:23 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Stealth is not a domestic. It is an import thru and thru.
And Its not that Stealths dont hold their value as much. Its the fact the 3000GT sold for more when new.
And Poly your Sebring alot Mitsubishi. Its more Mitsu than it is DC.
Old 05-28-2006, 02:00 AM
sort of off topic...im just curious, do stealth VINs start with J too? I know they were all made in Nagoya...just curious. There any insurance price difference between the two? hmmm...im gonna go do a geico quote! lol
on subject; Yea i think stealth value will rise in the not too distant future too.
Formerly BlinkRA182
