Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 07-26-2002, 08:14 PM
RyanSVT RyanSVT is offline
Question How far can a B18 be pushed?
I'm thinking about boosting a b18B1 powered LS/GS Integra. I can easily put a home made turbo setup together with a T25 or 14B turbo, Starion FMIC and some home shaped 2.25" piping along with a 1G DSM BOV. I'm wondering if the B18B1 is really as strong as people say...with 9:1 compression I imagine it can handle a decent amount of boost? Say 8-9 psi or can I go higher?
Old 07-26-2002, 08:42 PM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
Re: How far can a B18 be pushed?
u can go higher, if you have the proper fuel/ignition setup. st00pid ran 15psi on his stock block B18C1 which has the compression around 10 something. i say stay at 7psi or 8psi until you get your hands on one of those engine management system (hondata preferably)
if you're going turbo, its best to go with a full 3.0" exaust. it will help out with turbo lag and you will get more increased power with better response than going with a 2.25". 2.25" is like stock diameter.
Old 08-23-2002, 05:03 AM
Whitey001 Whitey001 is offline
i agree with gsteg:greenchai
Old 08-28-2002, 08:46 PM
crucialconflect crucialconflect is offline
Send a message via AIM to crucialconflect
B18B
I am also looking into a B18B for my 2000 hatchback.I have a few friends that are gonna build me a motor. Low compression pision, crower rods, low compression head gasket , and ported and polished heads and a 5 angle valve job. also they are talking about putting cams in it. I think toda is what they are. i was gonna run this for a while until i get my T4 turbo kit.
what do you think this setup will run ? 12's ?
Old 08-28-2002, 10:01 PM
GSteg's Avatar
Re: B18B
please don't tell me you guys are gonna go with an ungodly low compression like 8.5:1 or something like that. if you guys know your stuff..i say shoot for some higher compression pistons.
I love them sub wufers
Old 08-28-2002, 10:13 PM
why not go with low compression pistons ? more boost
Old 08-28-2002, 10:33 PM
GSteg's Avatar
the only time i would recommend with low compression is if you do not know anything about how to tune your engine.
compression is a form of power. when the pistons compress more, you'll make more power. so when you lower the compression, you also take away some power. and yes, you can run more boost afterwards, but mostly you'll just be replacing the power that you lost throught lowering the compression. it will take a B18B engine about 13psi, just to gain the same power as a B18C1 with 10psi. there are lots of benefit going with higher compression than with lower compression.
1. when you're not on boost, the higher compression acts like a normal N/A motor, making its power through compression. so even when you're not on boost, you'll get power.
2. spool up times demand cfm and velocity from the engine. the more cfm and velocity you have, the faster the turbo will spool up. the more compression you have, the more exaust you put out the engine.
3. with the higher boost, you'll run less boost, letting the turbo spin slower. when it spins slower, it reduces wear, letting it live a longer life.
at some point you have to lower it. don't think you can run lots of boost with 12.5:1 pistons. lisa kubo is running 11.0:1 pistons with 30psi. the perfect compression for tuning capability and power gains is 10.5:1
Old 09-02-2002, 11:38 PM
blowngsr blowngsr is offline
Send a message via AIM to blowngsr
b series motors are very strong i have 11 psi on a b18c1 w/ a charger so idont have an intercooler and it holds it. the only thing that b18b doesnt have is forged pistons so be careful. remember more boost= more power= more engin wear. but boost doesnt blow your motor up* or give you power*... timing is key in every thing more timing = more power but to much timing = detonation= blown motor,rings,pistons etc. if it were me on a stock bottom end i wouldnt push my luck so i wouldnt go over 10psi. :smoker2:
Old 09-07-2002, 10:25 PM
Rice_destroyer Rice_destroyer is offline
when i had my stock B18B1 motor i was running 8 psi fine w/ the v-afc hack. and this was untuned. having lower compression just gives you a wider range to tune with so you avoid detonation. your turbo may have to work a little bit harder to provide you with more air but it'll sure be worth it in the long run. also lisa doesn't have a STOCK block anymore and she can AFFORD the all out expensive tuning that is needed to run the compression that she's running and to add to that she doesn't run on pump fuel. so IMHO, running low compression on the a daily driven motor is the way to go.
94 SI, B18B1, port n polished head, SRP 9.2 slugs, Eagle Rods, Total Seal rings, ARP bolts, Nuformz blockguard, MSD ignition, apexi V-AFC(hack), PYR chip(8500 redline), 450cc injectors, bbk f/p, custom T3 kit w/MP equal length manifold, huge intercooler, restrictive 2 1/2' exhaust
next mod: Hondata+GM MAP
Old 09-17-2002, 06:59 AM
rice destroyer
what does your car run ? I WAS THINKING ABOUT DOING A BUILT LS or CRV motor. with a T3/t4 turbo ?
