Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 05-25-2006, 06:03 AM
zeek1403 zeek1403 is offline
96 Jetta radio
Where can I locate the fuse for my radio? I have no diagram on the fuse box on the kick panel.
Old 05-27-2006, 02:13 PM
FemaleVwTech's Avatar
FemaleVwTech FemaleVwTech is offline
Post Re: 96 Jetta radio
I think it is the 22nd fuse (10amp fuse), but I'm not 100% sure.
I would look it up for you but the program I use at work needs the vin for me to look up any information. It sucks.
Old 05-28-2006, 08:50 AM
stamptrain2 stamptrain2 is offline
Wink Re: 96 Jetta radio
Yes, the radio fuse is #22 and the fuse diagram is on the inside of the fuse cover flap. Hope you know how to reprogram the radio. If the power has been interupted, the radio will show "safe" in it's display. To get it to work again, you have to know the radio code number. I can give you the procedure if you need it. Good luck!
Old 05-28-2006, 10:10 AM
Yes, I know how to set the radio after it looses power.
Do you need your radio code? If you do, I will need your vin and the serial number off of the radio and I'll beable to get your radio code for you.
Old 05-28-2006, 10:17 AM
Re: 96 Jetta radio
Many thanks but I have the code for my radio. Hope you found your radio fuse.
