Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-24-2006, 11:09 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Angry Damn EGR!!
Ok, so I had in the past a Code P0401, which is something like a bad EGR valve. I replace the EGR sensor (with a used one[in good shape]), and still had the code. I then replaced the EGR valve (with a used one[in good shape]). It worked fine! Smooth idle, when I out the car in neutral, the rpms dropped perfeclty... everything was fine. This was a bout a month ago now.
Now, the CEL came on again, and it's the same code. However, the car is idleing fine and everything is acting normal. WTF? I replaced the 2 main components of the EGR system, it runs fine, but Im still getting the error. Any ideas here?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 05-24-2006, 11:11 PM
Killa's Avatar
Killa Killa is offline
Re: Damn EGR!!
man your car start give you problem now, may i suggest "boost time"
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 05-24-2006, 11:12 PM
david-b's Avatar
Dave is THAT guy
Re: Damn EGR!!
Umm yeah... This can happen to anyone. It's the EGR system, not a blown motor or anything.
75 Monte Carlo
Old 05-24-2006, 11:16 PM
Killa's Avatar
Re: Damn EGR!!
yea i know, dint your 4 and 5 hard to put in ?
GM FOR LIFE !!
95 camaro lt1
Old 05-24-2006, 11:17 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: Damn EGR!!
Did you check the egr solenoid?
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 05-24-2006, 11:37 PM
david-b's Avatar
Dave is THAT guy
Re: Damn EGR!!
Is that the little sensor thing?
If that's it, that's been replaced with a slightly used one also.
75 Monte Carlo
Old 05-24-2006, 11:50 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Damn EGR!!
Yes it is, and the valve is the silver piece that sits right next to that. What I did to help mine was take the pipe off that runs up to the intake mani and clean it out a bit.
95 Talon TSI AWD
97 Eclipse GST
Old 05-24-2006, 11:51 PM
david-b's Avatar
Dave is THAT guy
Re: Damn EGR!!
Yeah, I was thinking of that. I dont want to tho. lol. Is there anyway to test the solenoid if it's working right? Maybe I should put my old one back on and see if that works. The problem was the EGR valve before, so maybe the new used one that has a lot of miles on it just sucks. IDK.
75 Monte Carlo
Old 05-24-2006, 11:58 PM
Re: Damn EGR!!
Well if it has alot of miles on it then it probably wasn't in the best shape in the first place. Check out how much a new one is and if you don't want to spend all the money on it, I think I have like 3 or 4 laying around here. One of them is pretty damn new and one has less than 70k.
95 Talon TSI AWD
97 Eclipse GST
Old 05-25-2006, 02:30 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Damn EGR!!
EGR block off time? Will that hurt anything, make it run shitty, or anthing else besides emissions?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 05-25-2006, 02:45 AM
Re: Damn EGR!!
It's not worth the effor to try block the EGR, then you'll just have a code ALL the time.
95 Talon TSI AWD
97 Eclipse GST
Old 05-26-2006, 12:54 AM
david-b's Avatar
Dave is THAT guy
Re: Damn EGR!!
Im not blocking off the EGR. I replaced the solenoid with the original one from the car, not the one I got from another and reset the CEL. The car continued to run great. It was crappy at first, but I think that had something to do with the ECU reset and then the SAFC trying to mod it right away.
I didn't get a CEL with the original solenoid, so who knows. I also forgot I had a little hose going from the solenoid to somewhere at the back of the IM(?) that had a spliter in it. I forget why the one hose was out, but I remember I took it out for a reason. I didn't realize that it was such a strong sucking, so I blocked that off with a screw. Basically, jsut fixed a little open hose. I hope the original solenoid works fine.
75 Monte Carlo
