Old 05-24-2006, 08:52 PM
Dyno247365's Avatar
Dyno247365 Dyno247365 is offline
I finally broke something
I officially broke something on my car, unintentionally but knowingly, I'm so proud of myself. Finally something I broke that I have to fix instead of someone else breaking it before me.
The fuel filter was literally fused to the fuel line. I had all the wrenches set up right and a gas tank near by to catch spills. But I needed more, BRUTE STRENGTH!! This was the only way the filter was coming off. First I moved the gas tank out of the way and got my best breaker bar (pipe) on a crescent wrench that was on the filter itself. The bar held the wrench in place, it was going nowhere. My dad held the bar while my job was to put a shorter breaker bar on the vice grips on the fuel line bolt (It was all my idea XD). I worked the nut and bolt loose, had to take off the grips and turn a few times. It worked! Last hard turn and I hit my hand against the underbody, and that hurt, but the filter was LOOSE. We screwed the filter off and no fuel spilled out, we wondered why. The fuel line must have been clogged. 3 seconds later, the line cracks off from torsion.
Time for a new fuel line (gas tank to filter).
1996 Dodge Ram 1500 5.2L 5spd!!!
1987 Chevy Iroc-Z- -Needs a new cat
1992 Nissan 240sx 5spd- SOLD
Old 05-24-2006, 09:04 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
Re: I finally broke something
haha have fun with that
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 05-24-2006, 09:26 PM
Dyno247365's Avatar
Can anyone tell me what the line is called/size and if there may be any other lines attached to this that are clogged? Once again, this is the line between the filter and the gas tank. I looked it up and fine lines sells a steel repro for $65. I think this is the right line, 3/8?
Old 05-24-2006, 10:00 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Nice... now doesnt it feel better when you have to fix your own mess ups instead of someone elses?
Old 05-24-2006, 10:05 PM
Dyno247365's Avatar
Yeah..yeah it kinda does
Old 05-24-2006, 10:09 PM
666_speed's Avatar
666_speed 666_speed is offline
Son of Satan
Haha, I'm never happy when I break stuff :/
Old 05-25-2006, 09:04 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
oops, didn't see this thread when I replied to the other.
Bend your own line for $4 and some change for any adapters, you can get it preflared too.
Old 05-25-2006, 12:03 PM
Dyno247365's Avatar
It's really that cheap? what am I spending 65 bucks for *throws idea out the window*. Is it the same as making your own brake lines? I succeeded in that but it came out like crap. It works though...So first things first, I have to drain the 16 gal tank, which is thankfully only a quarter full. Any ideas how to drain it, since there's an antisiphon mechanism inside?
Old 05-25-2006, 12:24 PM
wrightz28's Avatar
Virtualy the same idea as the brakes.
It will be a few bucks more (2 tops) but I just spent $21 to replace 80" worth of line and adapters. And of the $21, $9.50 was brake fluid.
Old 05-25-2006, 02:44 PM
Dyno247365's Avatar
There's only one reason thy call me Quicksilver, because I'm quick as hell at fixing my car (when I have time, and I make myself time for it) I've already almost got the old tank fuel line out, It's coming out easily enough, but I'm not sure how to deal with this weird looking pipe connector thing, hence getting just this line out and replacing it from there.
Does anyone know what connector I'm talking about? Right now it's light green like the Statue of Liberty. How do I get the line out from here?
Old 05-25-2006, 03:46 PM
malletslinger's Avatar
malletslinger malletslinger is offline
????........Maybe you should take a pic...
Isnt the origional fuel line aluminum? Why would you replace it with steel?
Old 05-25-2006, 03:52 PM
Dyno247365's Avatar
O_O *checks line and takes a picture*
Old 05-25-2006, 04:48 PM
Dyno247365's Avatar
You're right, It is aluminum. Why would repros be steel then? Anyway, I should be able to get the line for cheap but I'm worried there's going to be a lot of customization.
The bottom line is for the fuel. I know you can't see it well but atleast now you know where to look if you have a third gen or you notice this type of connector before. It's like a metal pipe connecting the lines.
Old 05-25-2006, 06:12 PM
Could it be a support?
Since you are going to fabricate the fuel line yourself, why dont you just sectionalize it? Just replace the sections you need to and add some connection points...It would be a lot easier and would be just as good as if you had replaced the whole thing...
Then you can just tell yourself that if you ever have the engine and tranny out, then you can plan on dropping the tank at the same time and fabricate a complete line to replace the origional(that is if you think its necessary...)
What cha think?
Old 05-25-2006, 06:37 PM
Dyno247365's Avatar
What cha think?
At this point in the teardown of the fuel delivery system (sounds smart) We tried to siphon out the rest of the gas and only drops were coming out, which tells me something, there's a partial block in that line and I want to (at the very least) take out that full line and maybe replace it all.
I was going to add something, oh right! I found dirt and even water in the gas so when I figure out how to pull out the line, I'm draining the gas in an oil pan because it probably can't or shouldn't be reused.
