Go Back   Automotive Forums Car Chat > BMW > 5 Series
Old 05-24-2006, 05:57 PM
Mh2k6 Mh2k6 is offline
i have 2 problems on my car and i need help
well first one is not big problem but my right brake light is not working anymore and i dont know how to change it lol and my 2nd problem is that when i turn my car off i get message says Coolant level (Owner Manual) i dont have the manual and i dont know what to do with this message and i'd love to get a nice info/guide how to solve those problems. and i have BMW 1995 540I.
Thanks in advance
Old 05-26-2006, 07:48 AM
adm77 adm77 is offline
Re: i have 2 problems on my car and i need help
Hi there, your brake lamp is most likely inoperative due to a blown globe. It is quite simple to replace, but if you are not sure, I would drop past your closest bmw dealer and they will most likely do it for small or no charge while you wait. As for the coolant warning lamp on, I wood definetly have that looked at asap. you can check the coolant level yourself, by removing the radiator cap and filling it to max ONLY WHILE THE ENGINE IS COLD! 540's are known for coolant loss faults.
Old 05-28-2006, 07:12 PM
Thanks for info, but i figured out how to change my brake light but my radiator where it says coolant level is already full and i have no idea whats the problem.
Old 06-08-2006, 07:13 AM
Hey there, good to hear you worked out your brake lamp fault. With the check coolant warning coming up, the most comman causes would be an airlock in the cooling system or a faulty coolant level sensor. You can bleed the cooling system by openning the radiator cap, and backing off the bleeder screw next to the cap. Bleed the air from the system with the screw cracked open approx 2-3 turns, the ignition on, the heater on hot and fan speed one, this will allow water to travel through your heater core. Keep filling the radiator while bleeding the system. Once all the air is out and there is a steady stream of coolant coming out, you can close the
bleeder screw, but do not overtighten it (plastic). Give this a go.
Old 06-14-2006, 10:15 PM
i really appreciate your help, but i did that and i got rid of check ingine message but coolant level message show up after 8 min pf driving. and its really annoying
Old 06-18-2006, 07:12 AM
Thumbs up Re: i have 2 problems on my car and i need help
mate the only other suggestion is to replace your coolant level sensor, it is located at the bottom of the expansion tank (reservior)
