Old 05-24-2006, 06:37 PM
Robman95z Robman95z is offline
95z tranny probs
Hey Guys got a question my 95 z trans slips it goes into every gear its an automatic and u will push the gas and it will take a sec to click in to drive then u get abotu 5 mph and it will slip then pick up again but in reverse i can hold down the brake and push the gas and spin the tires so im lost if anyone can help there are no leaks trans fluid is full we changed the filter and the old 1 was bad but we forced the new one in and we think that it is pushed against the bottom of the pan maybe not letting the fluid flow properly???
Thanks guys
Old 05-24-2006, 06:43 PM
malletslinger's Avatar
malletslinger malletslinger is offline
Re: 95z tranny probs
Well, if it was working fine before you changed the fluid and filter, then you must have messed something up while you were in there.
You may need to retrace your steps...
Old 05-24-2006, 06:58 PM
No it was doing the same thing b4 we changed nething it got alittle better after we changed it...
Old 05-25-2006, 03:04 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
What did the fluid look like that was removed?
Old 05-25-2006, 03:46 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
and how did it smell?
how many miles?
lots of abuse?
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 05-25-2006, 04:57 PM
The fluid was nasty and the filter was hit there are little under 100k miles and it was really abused...
Old 05-25-2006, 05:19 PM
wrightz28's Avatar
Nasty as in brown and gritty? If so, she's probably had it. You could try some Lucas or other additives that claim to reduce slipping, Lucas does work on a mildly battered trans, just depends on how much friction materialis left. That's why they say if the filter has not been changed and the trans has over 80K miles on it, it shoul dactually be left alone as the friction material although no longer on the discs, remains but stays in the fluid.
Old 05-26-2006, 09:27 AM
yeah im gunna replace the filter and put it in right this time and replace the fluid and try that lucas stuff see how it works.
Thanks Guys
Old 05-26-2006, 09:56 AM
wrightz28's Avatar
I'd try 2 bottles of lucas and the rest a good quality ATF.
