Will I have to replace the entire car engine?
My car started to make these funny sounds the day before yesterday... A mechanic told me that it was the crank bearings and that I should replace the whole engine? Is that logical? or could I just replace the crank bearing. Pls inform me of what is the most logical and economical thing to do. Thanks 1983 chevy caprice v8 305
Re: Will I have to replace the entire car engine?
if you hurt a main bearing or rod bearing, you would have to erbuild the engine, youd most liekyl; have filiings throughout th motor and the crank is most liekly hurt to, take it to another mechanic before you do anything though
Formerly Blownalcoholboy 1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi) Best ET 1/4: 8.35 @ 170mph (275 drag radial) Best ET 1/8: 5.44 @ 132mph (275 drag radial) Best 60': 1.31 on the back tires (275 drag radial) AF User Rules/Guidelines http://www.automotiveforums.com/vbul...uidelines.html |
A spun rod bearing will result in a bad connecting rod or two and also a bad crank journal. A spun main bearing will result in damage to the block which will require an align bore and special spacer bearings. Either way, you'll need a crank. There's also a good chance that with a spun rod, the piston crown will be crushed onto the rings due to cylinder head interference (from grossly increased rod bearing clearance).
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
That's all good, but an '83 305 had 14cc dished pistons and a tapered/relieved area around the upper ring land. There will be plenty of other damage to warrant replacement, however.
Hey!!! I Found Out It Was My Crank Pulley Buts Thanks Alot Guys You Were Very Helpful
The #1 and #2 pistons slammed into their respective heads and had a nice chamber-shaped imprint on the "flat" area of the piston.But, I digress. Comingofage - As for the pulley, it was likely the harmonic balancer - the rubber "seal" tends to extrude over time, allowing the outer ring to spin freely of the balancer hub. Makes a hell of a racket, glad to see that's your only problem. They're fairly easy to replace.
such as the L69 and so forth good luck
Randy [email protected] '78 Grand Prix all original 78k miles 301/auto '82 Trans Am 5.0 and th350 '84 Caprice all original 99k 305 and 700r4 '85 K-20 350 and 700r4 and NP208 3.21 axles '88 Toyota pickup 2wd 2.4L EFI and A43D AOD |
