Old 05-24-2006, 11:36 AM
billibong's Avatar
billibong billibong is offline
P0300 Trouble code and SES light
Hey guys, I did a search on the TC that I am throwing, and didn't find anything that was JUST a P0300.
'99 Blazer LS 4.3L 4X4, 4 door, 125K ish.
Here are the symptoms -
driving into work today, up a slight hill I noticed hesitation and sputtering - did't act like it was going to die - just sputtering and bucking a little.
turned around - called the boss, "not showin' up today, nah nah" - drove to Advanced and got the code scanned - P0300
Picked up some new AC Delco Plats and I will be changing them out
I recently did a tune up - about 20K or so ago - and replaced plugs, wires, cap, rotor, fuel filter. Plugs were Bosch Plats, because I didn't know about the problems with them at the time - thus the purchase of AC's today ($6 each!!!)
Did a coolant flush 4K ago.
Cleaned MAF when I got home, just to see if it would help, not much.
Oil is clean and recently replaced, no signs of coudiness or milkiness.
My question is, in your knowledgable opinions (much love for this group) does this sound like a plug problem, or should I start expecting something more??? Possibly beginnings of fuel pump problems (I would have expected it just to die)? EGR clogged or blocked - is it cleanable in the '99s?
Help me please!!!
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
Old 05-24-2006, 11:51 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: P0300 Trouble code and SES light
Help me please!!!
You are headed in the right direction with the AC-Delco plugs.
When you pull out the bosch plugs look real close at the ends of them you may see your missfire.
And be sure to drop the bosch plugs in the trash can or take them back and demand your money back on them.
A code P0300 just says you have a missfire.
Get the plugs in and clear codes and see what it does.
Let us know how it goes.
If it still does it post back.
Good Luck
MT
Old 05-24-2006, 01:13 PM
billibong's Avatar
Thanks for the quick response MT. I was hoping to hear something like this, I just hope that it clears up the problem. I will be changing them out, and I will let you know if it clears up the problem - because if it doesn't it's right back on hear to solicit more help!!..
billibong
Repairs:
Old 05-24-2006, 07:36 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
i know the 96+ blazers also have some sort of spider injector that can leak/fail (like the damn cpi's ). if changing your plug along with a computer reset doesn't do the trick, then i would check that spider. FAQ section has this thread about replacement if thats turns out to be the problem; http://www.automotiveforums.com/vbul...d.php?t=559014
another suggestion; a bad O2 could also cause a PO300 (i had it happen). Have u replaced them previously?
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 05-25-2006, 01:14 PM
billibong's Avatar
Swapped out the old (24K) plugs and put in new AC Delco Plats, properly gapped to .060. I am still having the same problem.
Is it possible that this is the EGR valve getting clogged with some carbon build up? I will pick up a gasket for the EGR this afternoon and pull it to check.
Still a little frustrated, and I hope I can find the problem soon.
billibong
Repairs:
Old 05-26-2006, 10:08 AM
billibong's Avatar
Finally found the problem!!
There was a misfire being caused by my "new" distributor cap between the four and five cylinders. Looking at the cap there was no sign of a problem, but had someone check it out with a full diagnostic scan and there you had it.
Lesson learned, as with Spark Plugs and getting the AC Delco's vs any other crap, go with the top shelf distributor cap from someplace like NAPA instead of what you get from Advanced or Autozone - as MT - 2500 says "do it right the first time"....
billibong
Repairs:
Old 05-26-2006, 10:26 AM
MT-2500's Avatar
AF - Advisor
Billibong
Thanks for posting back and letting us know how it went.
Glad you found the problem and got it going good.
And a big 10-4 on the parts. Always get the good stuff.
The good oem or oem quality type parts only hurt one time.
That cheaper stuff can bite you in the rear many times.
Good Luck
MT
MT
Old 05-26-2006, 01:32 PM
billibong's Avatar
Yeah, I guess I learned my lesson on this one. I figured to go cheaper on a critical part and it bit me on the a$$!!
billibong
Repairs:
