Go Back   Automotive Forums Car Chat > Volkswagen > Passat
Old 05-24-2006, 10:59 AM
Black Magic Passat Black Magic Passat is offline
Angry Power Door, Sunroof,Alarm, etc.Electrical problem
I hope someone can HELP..............The power door locks and the sun roof, dome light, trunk switch, gas door won`t open, the Multifnction Indicator on dash stopped working, Odometer resets itself every time you start the car, The trunk open light stays on, factory Alarm don`t work and clock don`t work. Is it the Ingition switch, Door lock, or the Alarm modual?
Can some one help me?
Old 05-27-2006, 03:42 PM
FemaleVwTech's Avatar
FemaleVwTech FemaleVwTech is offline
Post Re: Power Door, Sunroof,Alarm, etc.Electrical problem
You need to check all your fuses on the left of your dash. Sounds like one of the fuse has blown.
Try fuse 6 (5amp mini) thats for the Comfort Control Module.
Old 05-29-2006, 08:56 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
hope you know wiring repairs, Pull up the carpet on the driver side front. (have to remove the seat and the sill pannel to get carpet up) Look at the wires going to the black box ( the comfort/alarm module is in there) for any green corrosion. If there is corrosion than repair it and clean it off. If it fixes the problem than good, if not than you need to replace the comfort module thats in the box.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
