Old 05-24-2006, 01:02 AM
mustardstain mustardstain is offline
Back Door Lock buzzing
I have a quick question about my back door lock. When I unlock or lock my doors using my power door lock switch from my keychain I hear a sort of buzzing sound from the door. Half the time it does this and doesn't lock and half the time it is fine. Could my Power door lock be going out? Any ideas what I should do and how much it may cost. 99 jeep cherokee
Thanks
Old 05-24-2006, 07:06 AM
dave92cherokee's Avatar
dave92cherokee dave92cherokee is offline
Re: Back Door Lock buzzing
Does it ever act up if you use the power door lock and unlock that's inside the car on the door or just with the remote?
Old 05-24-2006, 07:40 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
I've got a 2000 Grand Cherokee with the same symptom. It started as a buzz and intermittent function to not working at all and squawking like a goose. I believe it's a stripped out gear in the actuator for the locking..... time to open up the door and do a replacement!
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 05-27-2006, 02:29 PM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
I have same problem, but I am too lazy to fix it. Power door locks have to be in sync, sometimes they get "sticky", the mechanism need lubricating; that is the the mechanical linkage is sticking. It also means you have to remove the door panel to lubricate the mechanism. Best to do all four and even the tail gate.
I use to work in a dealer where we had to do that all the time.
I get around it by cycling it, that is do a lock and then unlock and then a lock from the remote.
However, as fred says if it is stripped, you got to get in there anyhow, so start by removing the door panel.
Let us know how that goes.
Old 05-28-2006, 11:42 PM
Thanks for the replies. As soon as I get some time I will see what I can do! Thanks
