Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 05-23-2006, 07:32 PM
wraydeeoh wraydeeoh is offline
'87 Civic Si ECU LEDs 1 & 8
Purley stock '87 Civic Si has been running well...237,000 miles. Recently began hard-starting when warm and PGM-FI warning now lights along with LEDs 1 and 8 on ECU. Using AutoZone on-line repair manual, checked chart for appropriate trouble shooting...crank angle sensor tests good. Replaced plugs, wires, cap, rotor. Runs, but idle is a bit sloppy and smelly..like a rich mix. Have had problems with sunroof drains leaking onto passenger side floor, so I pulled seat to check ECU for invasive corrosion. Plenty on the surfaces, but connections seem clean. Bottom line: warning light, sloppy idle, LEDs 1 & 8 still a problem. Any suggestions? Thanks..from a New England Si daily driver.
Old 05-23-2006, 09:16 PM
pimpmcdaddies's Avatar
pimpmcdaddies pimpmcdaddies is offline
Re: '87 Civic Si ECU LEDs 1 & 8
Impressive mileage,Honda should be proud.
Old 05-24-2006, 03:27 PM
Yeah...I certainly can't complain. And, since it still gets 35+ warm weather mpg when it's running right, I really want to keep it going as long as possible. Never thought I 'd see the day when it would cost over 30 bucks to fill up a Honda!
Old 05-24-2006, 04:54 PM
lxndr's Avatar
lxndr lxndr is offline
AF -Advisor
Sounds like a bad O2 sensor to me.
Code 1 is for the O2 sensor, code 8 is for the crank angle sensor which is located in the distributor. On a car of this age with so many miles on it, I'm suprised these parts didn't go bad sooner.
Click this link for more info:
http://www.automotiveforums.com/vbul...9&page=1&pp=15
Old 05-24-2006, 06:52 PM
Thanks, lxndr...I think I'll give that a try. Although the crank angle sensor seems to test okay, it looks like that should be the next thing I replace. But last tiime I checked, that meant changing the whole distributor. Still true?
Old 05-24-2006, 07:57 PM
Yep,worth preserving.Too much unnessessary gadgetry on modern cars for me so I'll stick with the Civics.I just spent many hours restoring the underside of mine.Over the worst of it,now ready for the welder.Was nice to drive it again after having it stuck in the workshop for weeks.
Found an interesting article from a 1988 "Autocar" mag.A trial between Civic,205GTI,Renault 5 Turbo,Suzuki Swift,Uno Turbo and Austin Metro Turbo.(Very poor UK hatch,now totally extinct.)The two French cars were most popular but when you look at the equasion now the Honda is the most durable.All the other contenders are gone apart from a few loved 205GTI's,I've had a few of these and i could not have as a daily runner.They run like a dog when cold so not cheap to run.Were these cars available in the USA?Hopefully we did not inflict the Metro on you...
Quote from mag..."an honourable mention to the Honda,roomy,practical,economical,almost certainly the cheapest to own,if not as much outright fun to drive".
Old 05-25-2006, 07:35 PM
Interesting info. Hadn't heard about that comparison before. Speaking of welding, rust around the edges is just now becoming problem. Some spots on the undercarriage, too. Is that what you had to repair, too? Biggest body complaint right now is water leaking in through what I think are the drains coming down from the sunroof. It appears to come in under the dashboard in both corners. Anyone know if this is an accurate assumption on the '87 Civic Si? Is there anyway to stop the leaks short of plugging the drains from the top? And, by the way, the weatherstrip around the roof glass has seen better days, too. But, I haven't been able to find a replacement.
Old 05-25-2006, 11:15 PM
Sounds like a familiar story...Hate to be the bringer of doom but your leak symptoms is the same as mine.I wondered/hoped it was a blocked or split sunroof pipe when I noticed a damp carpet, but after pulling up the underlay matting high in the corners found the dreaded rot.
The problem starts under the front wheelarches where the plastic splash guard clips around the inner wing/engine compartment panel join.20 or so years of road debris collects here which results in rust holes and water entering the passenger compartment.As if this is not tragic enough the water collects under the sound deadeners on the floorpans which then leads to corrosion where the end of the torsion bars fix to body which is obviously not good .
The good news is that the whole front end is held together by 10 mm bolts and comes apart real easy though be a good idea to jetwash under arches first and lube all fixings in advance.
I've ground/cut all the rotton bits out,treated the bare metal ready for welding,welded up and then some good protection.I was unlucky with my Si,it was driven up a muddy track 6 days a week since 1994 but was still sound enough for a good repair.
I also found corrosion at front of inner wings where the air intake runs so 2 more plates required there.I've also put plates above torsion bars and sealed from below.Carpet really needs to come out for this but at least you can check/protect the rest of the floor.
Go on,get it sorted and see if you can get 300k out of the old girl,you'll miss it when it's gone!
Re.Sunroof gasket.I've heard if no new gasket available you can inject the hollow rubber with silicone which helps to make seal with the glass.sounds messy so cover your seats...
Old 05-26-2006, 07:08 PM
Thanks for those tips. I'll be checking those spots. I was thinking it was the sunroof drains because the leaks happen even when the car is sitting still. Actually, it's kind of weird. If I park with the nose facing uphill when it raining, it almost never leaks. But, if it's parked on level ground or with the nose downhill, it always leaks. A light rain doesn't cause a problem, but a heavy rain..like today .. comes gushing in. I know what you mean about the undercarriage. Last year I spent a week during a New England January under the Si replacing the fuel pump and the rusted lines to it. That's when I noticed the spots of rot blossoming in a few places.
Old 05-26-2006, 11:40 PM
hmm,you could temporarily seal up the sunroof with tape and see wheather the car stops filling up to give you a clue...
Old 05-27-2006, 06:52 PM
Great idea! I'll give that a try. Thanks. If it does turn out to be the sunroof drains, how do I track those down? Pull the fenders to get access?
Hey, lxndr...put in a new oxygen sensor. Looks like someone did a chop job on the old one. I found 3 splices in the wire from sensor to harness. Reduced that to one with new unit. #1 LED on the ECU is now dark, but #8...crank angle sensor...still lights. Disconnected both battery neg and #10 fuse to erase problem code, but it still lights. It's definitely idling smoother, so I'm taking it for a short spin to see what happens. Thanks for your help.
Old 05-28-2006, 01:54 AM
the pipes run down the pillars and kick out at top of inner wing,if bunged up some wire may pick debris out then some (careful) air line use.
Not a leaky screen is it?You can test that by taping it up too...
mix some (weak )bright coloured water based paint with some water to tip on test areas to help you find problem...
Old 05-28-2006, 03:44 AM
lxndr's Avatar
AF -Advisor
I have a CRX SI and my sunroof drain tubes sometimes popped out of the rubber elbow that diverts water out of the car. On a CRX the water drains towards the rear of the car, and I always knew if one of the tubes had popped off because the spare tire area would fill with water.
Your sunroof problem could be as simple as the problem I had, which can be easily remedied with a single zip-tie.
Old 05-28-2006, 07:30 PM
Thanks for the tips, folks. I'll be checking them out during the holiday tomorrow..after I get home from work.
Old 06-10-2006, 11:54 AM
Now back to the ECU trouble lights. Hey lxndr, new oxy sensor cured one problem. Runs smooth with no trouble light until fast idle drops down. Then it runs raggedly and #8 lights up again. Looks like crank angle sensor is the culprit now, but nobody lists it as a part separately. Repair manual suggests that replacing the whole distributor is the only fix. Honda price: $600. Jobber price: $307. Anybody know of any other options? Thanks.
