Old 05-23-2006, 01:02 PM
SaphusGT's Avatar
SaphusGT SaphusGT is offline
left axle shaft seal/transmission leak...
So yeah... im doing my best to make this used GT something fast, drivable and good... It just seems as though the problems are endless... I have It at a transmission shop, where they've rebuilt the trans twice now... now they're talking about a bent axle (?! ) so, if anyone has any advice as to getting started again once it is finally done, that woud be great.
Old 05-23-2006, 03:50 PM
Igovert500's Avatar
blue + red light magnet
Re: left axle shaft seal/transmission leak...
Find a new shop
How did you bend an axle? If you don't know, then find a new shop.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 05-24-2006, 10:13 AM
2old 2old is offline
I agree...
I was thinking about it and realise axles don't usually bend... They break. Axles are designed to undergo torsion which means the shaft has to be more hard (rigid) then ductile (flexible) and unless you managed to overheat the shaft (like had the car over a fire) it will not bend.
The only this I have seen is if you torqued the teeth holding the shaft in place, but you would have needed to have had something seize the wheel all of a sudden while moving at a pretty good speed or somthing hit the car while it was in gear (something big... Like another car).
Old 05-24-2006, 10:24 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
i've seen axle shafts bend. i once worked in a full service reputable auto repair shop, and a grand cherokee 4WD came in. one of its rear wheels had bad bad curb rash, and consequently, that wheels axle was bent. we could see it be remove the wheel and spinning the axle, and it did not rotate about its normal axis, but had a noticeable wobble.
so unless you nailed a curb really hard, i'm with Igovert and 2old: it is very hard to bend an axle. if they say its bent, let them show you proof.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 06-09-2006, 03:44 AM
SaphusGT's Avatar
my dad and i are both aware that the car was in an accident before i got it...
