Go Back   Automotive Forums Car Chat > Nissan > Quest | Presage | Serena
Old 05-23-2006, 10:33 AM
Harrinj Harrinj is offline
Power Antenna Issue
Hi all,
My power antenna no longer works and I can't figure out how to get to it to fix it. Do you go in under the fender or between the door jab? Both have panels blocking access. Also, do I need to replace the entire power module or just the mast? The antenna makes a clicking sound when I turn the radio on/off, so I know the motor's working. Any ideas would be appreicated....
J.D.
Old 05-23-2006, 10:34 AM
Re: Power Antenna Issue
Hi all,
I have a 1998 Nissan Quest GXE and the power antenna no longer works. I can't figure out how to get to it to fix it. Do you go in under the fender or between the door jab? Both have panels blocking access. Also, do I need to replace the entire power module or just the mast? The antenna makes a clicking sound when I turn the radio on/off, so I know the motor's working. Any ideas would be appreicated....
J.D.
Old 05-23-2006, 10:36 AM
Hi all,
J.D.
Old 08-30-2006, 06:04 PM
Fecomosis Fecomosis is offline
Mine does the same thing but make an LOUD squeeling noise like a dieing chimp.
I did some research, since the Antenna is already up I was going to unplug the motor. I found out that you can access the plugs from under the dash/computer area.
What I would do is go to
www.alldadadiy.com
create an account for 24.95 and get all the information you need to do it your self.
