Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 05-23-2006, 08:27 AM
cbfloyd cbfloyd is offline
97 SC2 Shifting problem
Hi, I have a 97 SC2 with an automatic transmission. There is a shifting problem that is sort of weird. If the shifter is in park and I go to drive the car starts out fine but will not shift out of that gear. If I go from park to 3 and start off it shifts perfect. Here is the weird thing. If after starting off in 3 and then shift to D if goes into the last gear and works perfect. I can start-stop slow down speed up and it shift perfectly through all gears. It does not matter if it is hot or cold. But everytime I go from park or reverse to D I have to go through this put it in 3 and then to D. Could this be a shifter linkage adjustment problem? Thanks for any help.
Old 05-23-2006, 11:31 AM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
Re: 97 SC2 Shifting problem
ok so if you go from park to overdrive and drive the car, it wont shift out of first?
Ian
Saturn Tuners Club-OH Chapter President
1993 Saturn SC2 rebuild project for dad
1995 Saturn SL2 current daily driver /w a lot of work
2007 Chevy Cobalt injen cai, full lsj exhaust, dc sports fsb, progress springs and rear sway bar, enkei wheels/hankook rubber --*boost in progress
Old 05-23-2006, 01:12 PM
Yes. I know it sounds weird but that is exactly what it is doing.
Thanks
Old 05-25-2006, 03:59 PM
shift solenoid is about all i can come up with.
Ian
