Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-22-2006, 10:33 PM
weathermedic weathermedic is offline
01' Rodeo transmission question
Is it possible to have too much fluid in the tranny? I had the tranny serviced at the dealer on Friday and when I got home, I noticed the drain and filler plugs were leaking. I tightened them myself. I did some driving over the weekend and noticed the tranny slip once. I was unable to check the fluid because these trannies don't have dipsticks (who's the genius that thought of that?) Brought it back to the dealer today, and told them to check the fluid. The mechanic has it up on the lift and decides to put a different type of filler plug (allen wrench type with a rubber gasket) just to be on the safe side. When he pulls the old filler plug out, I noticed the fluid pour out of the tranny. According to the Haynes repair manual, you are only supposed to fill the tranny until the fluid just starts to come out of the filler hole. The mechanic then proceeds to pump MORE fluid into it before he puts the new filler plug in. I figured he's the mechanic, he knows what he's doing. On the way home, I felt the tranny slip once. I said to myself "enough is enough" so I crawled underneath and loosened the filler plug to the point where the tranny fluid just trickled out (after it poured out for a bit) I then took the truck on a test drive and no slippage.
I was just curious if anyone has ever heard if having too much tranny fluid can cause some slippage.
Jason in NYC
Old 05-22-2006, 11:30 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 01' Rodeo transmission question
CHeck the FAQ's. I think you are suppose to check the tranny fluid while it is warm, and while the engine is running.
What is your history on tranny fluid changes?
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 05-23-2006, 08:37 PM
I have 60k, never had the transmission serviced/flushed until Friday. The mechanic had the engine running when he checked the fluid and pumped more into it. I also had the engine running when I let the excess fluid drain out of the filler plug hole.
Jason in NYC
Old 05-23-2006, 09:05 PM
Isuzu Guy
60k is a bit long to wait for a flush. Many folks here would advise to drop the pan if you are past 50k instead of flushing.
These tranny's like flushes every 25-30k. Search here and the FAQ's on issues of waiting to long between flushes.
-Ryan
Isuzu Moderator
Car Show Tips
Old 05-24-2006, 01:06 PM
My bad. The pan was dropped, new gasket installed, new fluid put in. All at the dealership.
Jason in NYC
Old 05-24-2006, 04:49 PM
Ramblin Fever Ramblin Fever is offline
60k is a bit too long to wait. But if you've never towed or done any extreme mountain driving, I personally wouldn't fret too much. Constant stop/go driving can be rough too, but hopefully your servicing helped.
*sometimes* when you change the transmission fluid in a higher mileage tranny you can get slipping because the old fluid was holding things together, sorta-speak; hopefully it doesn't continue.
And in another 5k miles or so, drop a bit more fluid out and replace with new over the course of the next 10k miles or so. As dropping the pan only replaces 5qts of new fluid, mixing it into 4qts of old fluid remaining.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
