Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 05-22-2006, 09:06 PM
400wagon 400wagon is offline
caddy intake question
I was wondering if the caddy intake that people use for the lo5 caprices would also fit on a q-jet. I don't know if the tbi and the q-jet are the same diameter, but it's probably worth finding out. It would probably be a good option for my carburated sm block.
Old 05-22-2006, 09:31 PM
CD Smalley CD Smalley is offline
Re: caddy intake question
Give a my a day or so and I can tell you. I have a caddy intake that I have intended to use on my 9c1. I can see if it will fit my 86. That's a good idea!
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 05-22-2006, 09:34 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Won't fit. The TBI is two barrel with a triangular 3-bolt attachment pattern.
Another thing is the angle of the two middle attachment bolts on the L03/L05 intake - they're a little more vertical than on the older pre-centerbolt heads.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
