Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 05-22-2006, 08:08 PM
RAOUL DUKE RAOUL DUKE is offline
Any Help!!
I have a 97 jeep grand cherokee laredo. I am having this problem with the brake light fuse blowing out causing the brake lights to fail. Obviously there is a short in there somewhere but I have not been able to locate it. I thought that I had fixed the problem because it has been fine for the past couple of months and then all of the sudden started blowing out again. Does anyone know where the most likely place the short would be caused at?
Thanks for your help
Raoul
Old 05-23-2006, 09:00 AM
legalfee legalfee is offline
Re: Any Help!!
I don't know of any place to look but to find the short to ground (or any short) get an accurate ohm meter (3 decimal places) and find the lowest point in ohms (from power to ground)With no power applied (disconnect the battery). That's where the short will be. It would help to have a wiring diagram too.
1984 AMC Wagoneer Limited (RIP - Burned)
1996 Chrysler Grand Cherokee Limited (for sale)
1999 Chrysler Sebring Convertible JXi
2004 BMW X3
Old 05-23-2006, 05:16 PM
Re: Any Help!!
Thanks,
I appreciate your help!!
Old 05-29-2006, 11:41 PM
rob doggy dog rob doggy dog is offline
Re: Any Help!!
remove your bulbs and see how the connections are sometimes the plastic melts away from the socket area as did mine on a 00 laredo dont know if yours is the same?
