Old 05-22-2006, 04:56 PM
appleseed's Avatar
appleseed appleseed is offline
Compound in panel lines
So I'm working on my the Revell 430 (I love this kit!!) and I'm finally finished polishing away. What's left is to clean up the compound from the panel lines. However, no matter how much I scrub with a toothbrush, the stubborn compound does not seem to want to break free. The water makes it look translucent and appears out of the panel line but once dry, the white powdered compound is still there! Drives me nuts!!! Does anyone care to share how they remove the compound from the panel lines?
TIA,
a
Old 05-22-2006, 05:02 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Compound in panel lines
toothpaste and a toothbrush usually works for me
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 05-22-2006, 05:06 PM
mickbench's Avatar
mickbench mickbench is offline
LOL beat me to it. I was gonna say "toothbrush". Works well for me too..
Old 05-22-2006, 05:13 PM
appleseed's Avatar
Wow, you guys are fast!!
I've tried the toothbrush and went as far as to try to work the bristles in the panel lines to massage the compound out. What I didn't mention was the I rescribed all the panel lines and made them deeper/sharper. That's probably what's killing me right now. Its just alot harder to get the compound out now. I'll try the toothpaste along with the toothbrush and see how that works out. Thanks!
a
Old 05-22-2006, 06:32 PM
winstona's Avatar
winstona winstona is offline
Have you tried to rescribe it again very lightly? Do it so light that you are not making the lines deeper.
You need an instrument that can penetrate deep enough.
Winston
Old 05-22-2006, 06:57 PM
appleseed's Avatar
Winstona- The thing about rescribing it again is that the paint buildup has made the panel lines really narrow and hard to get to. Doing so would risk chipping the paint... something I'm really hesitant to do. If all else fails, I'll redo the panel lines with paint and that should just cover up the color differential (but I really don't want to do that either.) Hopefully the toothpaste works...
a
Old 05-22-2006, 07:27 PM
freakray freakray is offline
AF Modelrater
Did you think of using a toothpick/cocktail stick with the ended sanded to a fine point and dipped in a drop of water to clear the compound out the panel lines?
AF User Guidelines
Old 05-22-2006, 08:06 PM
nugundam93 nugundam93 is offline
Blarg! Wort Wort Wort!
i just work on it with a stiff tissue paper, or a dulled toothpick for severe ones.
olly olly oxen free
Old 05-22-2006, 08:20 PM
appleseed's Avatar
Toothpicks are too thick but paper worked out pretty well. It got most of it out but there is still some left over. You can see the white compound on the left and right side of the hood panel lines--
I might just go ahead and put another wash on it when I'm finished to eliminate the white specks...
Thanks guys!
a
Old 05-23-2006, 02:57 AM
RallyRaider's Avatar
Zomby Woof
The toothpick trick always works for me, but best to get it quickly before it dries too much.
Old 05-23-2006, 03:20 AM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
I use a toothpick cut to thickness with a No 11 Blade.
Steve a.k.a. Hiroboy
Old 05-23-2006, 03:29 AM
mickbench's Avatar
Toothpick never works for either. Even if I sharpen the edge a little. Toothbrush and water works well for me, but I just rewash the panel lines if I get a stubborn bit of compound…
What works well for one, doesn’t always work well for others. That’s the beauty of this hobby. You find your own ways to make something work, and pass this knowledge on, and then the person asking for help can try them out, and see which one works best for them…
In this case, toothbrush, with stiff tissue and water… Glad it worked out for you. And VERY nice paintjob you’ve got there.
Old 05-23-2006, 04:25 AM
sjelic's Avatar
sjelic sjelic is offline
Toothbrush has to thick hairs (? is it the right word?), much better resoults are achived with wide hard brush slightly cut (so that those hairs are very short and stiff), I have one brush from my wife's cosmetics that works perfectly for this kind of problem.
Sasa Jelic
SCALEMAKERS
Old 05-23-2006, 04:42 AM
ales's Avatar
ales ales is offline
Forza Schumacher
I have found a rather effective method recently - you know those household spray bottles?
I found that if you hold the nozzle a few milimetres from the panel line and spray into it, the water will remove all polishing compound, even dried one. HTH.
Old 05-23-2006, 07:15 AM
drunken monkey's Avatar
Razor Sharp Twit
i tend to use a piece of scrap paper folded so that i have a little scoop to work with.
