Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 05-22-2006, 05:25 PM
bluelogic bluelogic is offline
PCV Value
Hello All,
I have a 2005 Ford Focus ZX4 SE. I'm doing the routine maintenance and I noticed to check the PCV value to have to take off the intake manifold. I looked at the procedure in my Haynes book and it looks like a surgeon’s job. Who decided to put a maintenance item that required removal of the manifold? Does anyone have a workaround?
Thanks
Bluelogic
Old 05-23-2006, 01:32 PM
mtmaurer8ooo mtmaurer8ooo is offline
Re: PCV Value
Well, for about 10 bucks more you could order the whole oil separator asy (which includes the PCV) from the dealer and just change that. I don't know if it will really be THAT much easier to change, but if you have to go all the way with it...you might as well go all the way. MM.
"Listen to me Hillary. I'm not the first guy who fell in love with a woman that he met at a restaurant who turned out to be the daughter of a kidnapped scientist only to lose her to her childhood lover who she last saw on a deserted island who then turned out fifteen years later to be the leader of the French underground."
Old 05-31-2006, 11:56 AM
Re: PCV Value
Anyone know another method to change the PCV value? I don't want to mess with the wiring harness. I heard there is an alternative method for the Zetec engines?
Thanks
Bluelogic
Old 05-31-2006, 07:04 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: PCV Value
the PCV valve on zetecs are located behind the exhaust manifold. All you have to do is get underneith the car and reach up behind the manifold and pop it out, You don't have to remove the intake manifold or anything like that.
But, I thought 2004+ Focues came with duratecs instead of zetec?
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 05-31-2006, 07:12 PM
Re: PCV Value
You are correct the duratecs have the PCV value in the Intake Mainfold. I was just asking if there is another way. I hate to mess with the wiring harness and having to break all those gaskets.
Thx
Bluelogic
Old 05-31-2006, 09:38 PM
shizznizz980 shizznizz980 is offline
Send a message via AIM to shizznizz980
Re: PCV Value
Whats a pcv value I have a 2000 Focus zx3 with the zetec I want to know if this is important.
Old 05-31-2006, 11:14 PM
pre98zetec's Avatar
Re: PCV Value
http://autorepair.about.com/cs/gener.../bldef_621.htm
usually you only replace them when they need it, i replaced mine at ~125,000 on my zetec.
-Josh-
Old 06-01-2006, 11:22 AM
Re: PCV Value
Yea, pre98zetec is right. The PCV value gets gunked up after being stuck in the engine for a long time. I just bought the car last year and I'm looking at what work I can do on it and what work that I'm not skilled enough to do.
Eric AKA Bluelogic
