Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 05-22-2006, 03:50 PM
gilligans_off gilligans_off is offline
1992 bonneville ssei starts, stalls then wont start
here is what ive done so far...
1.) http://www.bonnevilleclub.com/forum/kb.php?mode=article&k=33&highlight=coils I used this to check the coils... but i also picked up some used ones from a scrap yard and it didnt help.
2.) http://www.bonnevilleclub.com/forum/kb.php?mode=article&k=57 (i had codes cleared and only the cam sensor stayed and that was changed)
3.) Changed the MAF as it was tampered with and I thought it was part of the problem.
4.) Then i checked the fuel pressure with a fuel pressure tester buy first hooking it up and just turning the key and letting the fuel pump prime. then i started it and let it run for a bit and seeing if it droped and it didnt. then i turned it off and left the pressure tester hooked up to see if it lost any pressure and it lost only 3or 4 psi in ten min.
5.) then used this write-up to check and replace the sensor (magnet was fine and in tacked)... http://6007.us/cammag.htm
Then I made this post lol hope this gives everyone an idea what ive done thus far. It starts ok and when it runs for a bit maybe like 5 or 10 min. it dies and wont start for a few hours... any help would be great thanks
Old 05-23-2006, 03:46 PM
sixsmiles sixsmiles is offline
Re: 1992 bonneville ssei starts, stalls then wont start
I had the same issue on a 93 Bonneville, found a bad engine ground wire... Check Block to frame resistance if over 10 Ohms then run a new wire from engine to h frame. I have also heard of an intermittent ground at the coil pack.. wire was attached but crimp was only attached to 2 wires.
Best of Luck.
Old 05-24-2006, 12:27 PM
maxwedge maxwedge is offline
A990 racer
Question Re: 1992 bonneville ssei starts, stalls then wont start
Lots of stuff but no diagnostics, do you have spark when it won't start, do you have injector pulse, will it start by spraying starting fluid into the intake?
Old 05-24-2006, 11:01 PM
it has spark and but i havent checked the injectors... would they do that though? why would they stop after they got warm?
Old 05-25-2006, 08:23 AM
A990 racer
Well get to it, also, again will it start with spray into the intake, if so a fuel delivery or injector pulse problem is the issue, if not, not enough spark, no spark or injector pulse possible crank sensor, or icm.
Old 05-25-2006, 08:21 PM
it starts fine and runs... but after you drive it for a bit or it heats up she dies and wont start for a few hours. sorry i should have said that.
Old 05-26-2006, 01:11 AM
raymonator raymonator is offline
Send a message via Yahoo to raymonator
Could be the torque convertor clutch solenoid,very common problem on GM's.
Old 05-26-2006, 02:03 PM
A990 racer
Lightbulb Re: 1992 bonneville ssei starts, stalls then wont start
Not going to prevent the car from just starting.
Old 06-19-2006, 11:26 PM
could it be related to an alt. or battery maybe? seems that when it does run it runs good but then it dies and doesnt start until i charge the battery and let it sit for awile.
Old 06-20-2006, 02:26 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
check system voltage, with car off, should be 12.6-13.2, while the car is running, should be 13.8 to 15.2.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
