Old 05-22-2006, 12:37 PM
Drfloppy Drfloppy is offline
97 GP Traction control / ABS problems
Good afternoon, I would just like to start out by thanking everyone for helping me in the past, I always come here as soon as I have any problems with my car.
Ok, my 97 grand prix, which my girlfriend drives, is having problems with either the ABS or the traction control system. What will happen is, you will go to take off from a stop, and the low traction light will come on, even thou the tires are not spinning. Some of the time, you will go to hit the brakes, and there is a noise under the hood area, the noise it usually makes when the abs system is kicking in, and the car wont stop as well as it should because the abs is going off. My girlfriend doesnt want to drive the car, because she doesnt think it will stop..
Once and a while the abs light will come on, and the Traction Off light will come on, even thou I didnt turn it off. I hit the button to turn it back on, and it does nothing.. I was going to pull the fuse for the abs system and see if that does anything, but I figured I would check here first.. Sorry if this sounds confusing. Thank you for your help in advance !!
Old 05-22-2006, 12:55 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 97 GP Traction control / ABS problems
The first thing to check is the hub bearings. Most times, when both the trac-off and ABS lights come on, it indicates a wheel speed sensor problem. You can put an ohm meter across the plug of each hub, and it should read about 1k ohms. If not, the hub that's out of spec will need to be replaced.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 05-22-2006, 01:04 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Until you get the possibility of a flaky wheel sensor resolved you can pull the ABS maxifuse to inhibit the ABS modulation you are experiencing. The conventional braking system should still work. It drops power to the EBCM module. However, you will get a constant ABS and trac off light but the braking should be OK with no ABS modulaton or pulsing due to lack of a wheel reference signal.
Also, to be safe get it scanned with an ABS capable scanner.
BTW - Pulling the ABS fuse may cause an EBCM reset as will disconnecting the battery for a few hours. Helpful if something in the EBCM module just hung up.
Timeslip 08/12/06
AF Community Guidelines
Old 05-22-2006, 01:08 PM
So are we saying it could be a wheel speed sensor, or are we saying it culd be a bad hub bearing ? also, any idea on costs ?
Thanks again !
Old 05-22-2006, 01:11 PM
BNaylor's Avatar
Thanks again !
They are one and the same. If a wheel sensor is bad the whole hub has to be replaced.
Hub/Bearing with ABS wheel sensor
Timeslip 08/12/06
