Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-22-2006, 08:56 AM
drdrew33 drdrew33 is offline
99 Rodeo Coolant Coming Out Under #6 Coil Pack
Any Ideas what might be causing this, and how to fix? Also, Thermostat Replacement requires removing IM? 67000 miles. V6 DOHC 4x4.
Old 05-22-2006, 09:39 AM
lifelongslacker lifelongslacker is offline
Re: 99 Rodeo Coolant Coming Out Under #6 Coil Pack
Sounds like a blown head gasket, you could try aa compression check if you wanted to be sure.
97 Rodeo 3.2L, KC Lights, Air Hog Filter, Flowmaster 50 Series, Maxxis Bighorn MT's, 2" Lift.
2004 F150 FX4, Stock, so far
Old 05-22-2006, 03:29 PM
rodeo02 rodeo02 is offline
This is most likely a cracked cylinder head. Supposedly, 1998-1999 3.2/3.5's had a bad run of heads. The tell-tale sign is coolant in a plug well.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 05-22-2006, 04:31 PM
surferfletch surferfletch is offline
Something I hope I never see. Good luck getting it back in shape!
