Old 05-21-2006, 11:14 PM
1986TBIRDV8 1986TBIRDV8 is offline
Stupid Amp. Can anyone help me out?
The POS keeps going into safe mode whenever I turn up the volume on the head unit. What's the deal? It's a 600 watt Boss. Don't laugh. Please.
Old 05-22-2006, 12:12 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Stupid Amp. Can anyone help me out?
check the ground
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 05-22-2006, 10:19 AM
BlasZ24 BlasZ24 is offline
Check the load impedance.
Old 05-22-2006, 01:19 PM
Patrick Simmons Patrick Simmons is offline
Send a message via MSN to Patrick Simmons
Do you have it bridged?
Post Whores Wanted
http://www.cyvforums.com
Old 05-22-2006, 01:24 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Its either impendance or a short, check all your wires.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 05-22-2006, 08:32 PM
NAVY IC's Avatar
NAVY IC NAVY IC is offline
I think if your amp had a shortened circuit it would go into protection immediately once it's energized, (if it has short protection).
Are there any labeled indicating lights that cut on when you're having your problem...??
SELLING THE HONDA...
Old 05-22-2006, 10:13 PM
Thanks for the responses. It's a 2 channel amp so I have it bridged. I only have one Kicker right now. The green light on the side of the amp goes off and a red one by it comes on. It's the light that indicates it is in protection mode. I have to shut the HU off then turn it back on in order to get the amp to turn back on. I've checked the ground and it's good. What about the impedence?
Old 05-22-2006, 11:40 PM
What model amp and sub i need exact models. If the amp is only 4 ohm stable bridged and your running 2 ohm then your impendance is to low. Or your amp could have a problem internally. Did you check the wires to the sub in the box you could be shorting out when the sub hits.
One other thing my friend had a pioneer amp and sub in his truck, he had the same problem i spent an hour looking at wires, pulled the sub out of the box, everything i could think of. Well the amp would only stay on when the volume was low. Well his sub was blown and the voice coil ws starting to come unwound, so it was shorting at higher volume. Listen for any scratching sounds, or push and listen for them the sub could be blown.
Cardomain
Old 05-31-2006, 10:47 PM
91EURO3.1L 91EURO3.1L is offline
Im having the same problem! Whenever I turn up the volume to a certian point on the head unit, the subs just stop. I turn it down a little bit, they come back on. It pisses me off because it is brand new. I don't know what "gain" is or does and there is one other one im not sure of (I at least know what bass boost does). Im thinking adjusting those will fix my problem but i dont know what to set them at. if it helps i have two 12" pioneer subs( I think 600 max each) and a pioneer 800 watt mono amp.
Old 05-31-2006, 11:23 PM
JunkTitleGolf's Avatar
JunkTitleGolf JunkTitleGolf is offline
The other day I had a problem similar but after changing ideas I realized what was wrong. Here is what I was doing...gf's car...Sony Xplod 4 channel amp and another amp for sub. Power is going through distribution block. Sony amp has enough power old sub amp gets power...new amp gets power then cuts out...problem the fuse at the block was rated too low. Thus not letting enough power go to the amp to make power for the sub.
1995 VW Golf
Cold Air Intake
Cat delete
Full straight pipe exhaust
4 gauge big 3
Pioneer head unit
Power Acoustik Amp
Cerwin Vega Vmax sub
Old 06-01-2006, 12:32 PM
bjboertje's Avatar
bjboertje bjboertje is offline
^^ wouldn't that have made the fuse blow??
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 06-01-2006, 01:46 PM
Yes generally if the power is to much for the fuse or it shorts you burn the fuse.
Cardomain
Old 06-01-2006, 02:31 PM
Well, hmm...I guess my problem wasn't solved. I thought the fuse on the block was only allowing the rated power to go through. Hopefully someone can help me.
1995 VW Golf
Cold Air Intake
Cat delete
4 gauge big 3
Pioneer head unit
Power Acoustik Amp
