| Off-Topic Talk about anything other than cars. |
Finally RUNNING !!!
The GSX is now running. It hasnt been running for some time now. Since this is my first turbo car I have ever worked on I carefully put back everything.
However when I rev it to say 3-4k white smoke comes out. Its comes out next to the exhaust manifold and timing belt. It comes up slowly so I cannon pinpoint the location. Its not exactly white but its not either white or blue. I cannot say with certainly but it comes out of there when its in the higher RPM's. Also since I had the turbo out when I put it back in I am certain I did it perfect but say I messed up, how can I figure out if the turbo is getting oil and coolant. I dont want to fuck up the car now when its complete. Thanks guys I hope I dont mess it up now
1997 Eclipse GSX |
Re: Finally RUNNING !!!
Sounds like an exhaust leak. Did you bolt the exhaust mani on good? Use a good gasket? Is there a crack on the manifold?
Just test ran my car and I got another problem. I fixed the exhaust leak but My car wont go over 2K. Its like I am draggin a frikin tank behind me and it wont go any faster. BOV wont make a sound. I dont have any huge boost leaks maybe a small one but not big enough to sop me from accelarating over 5 mph. Also the car overheated big time, temp gauge went through the roof in like 1 min, both fans are working, coolant all the way , nothing has been touched so I know something is wrong. Also before, when left idleing the car had like -9.5 vac and now its like only -4. I am confused, so any opinions ?
1997 Eclipse GSX |
It sounds like you have a blown head gasket. Did you check your coolant level? Do a compression test ad see what that says.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff. http://www.ratemydsm.com/member/ez1286/?member=ez1286
