Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-21-2006, 10:47 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Maxing out my turbo....question
Okay, so as soon as I get around to ordering a fuel pressure regulator so I can install my 650cc injectors, I plan on maxing out my T28 turbo. The turbo has a bigger compressor wheel and has "50 trim" dimentions. I am estimating that the turbo could put out close to 350hp at the crank maybe? Anyway my question is... with my upgrades am I ok to go ahead and max the turbo out once I get my parts on or am I missing some things? Thanks.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 05-21-2006, 10:50 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: Maxing out my turbo....question
if ou dont have a mls head gasket and or arp head studs your looking at a max of 20 psi before you blow it headgasket that is
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 05-21-2006, 11:05 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
You'll need tuning/logging stuff, some pretty good race gas, and cams/SMIM will help a lot. I think that turbo is near the evo III 16g, but not quite. I think like 375 whp is about it. Without cams/SMIM I wouldnt expect to make more than like 340 on race gas, high boost pressure, and a pretty good tune.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 05-22-2006, 12:39 AM
blk_srt's Avatar
IIRC a t28 isnt much bigger than a big 16g so your looking at making around 340hp with all the mods
Mods:
Old 05-22-2006, 12:42 AM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
it's smaller than a 16g
now - 2000 civic
soon - 2002 is300
Old 05-22-2006, 12:43 AM
blk_srt's Avatar
sbr claims "it has big 16g power" so thats what I was going off of. I thought it was smaller but couldnt back it up on short notice.
Mods:
Old 05-22-2006, 12:45 AM
it's just a T25 with a larger compressor wheel. Spools just a bit past the T25, it's a good turbo.
Don't trust vendors on everything....especially slowboy....
now - 2000 civic
soon - 2002 is300
Old 05-22-2006, 01:20 AM
kjewer1 kjewer1 is offline
AF - Advisor
That turbo should be very easy to max out on race gas. On pump, it's a little trickier.
I ran my 11.3 at 126 passes on a stock head gasket. MLS is nice, but not necessary. On a 2g especially, studs should be done for good measure, but if you don't knock you will likely get by on the stock bolts. This is a small turbo still...
On a small turbo, cams and SMIM don't increase the max HP any. They simply allow you to max out the turbo's flow at lower boost. Which is good for pump gas power, but doesn't really matter much on race gas. With larger turbos, cams and SMIM may be the only way to max them out at reasonable boost levels.
This turbo probably is close to 16g power levels. Basically a little bigger than a 14b. For comparison, a T25 flows in the low to mid 20s, a 14b maxes out at 30 lbs, small/big 16gs around 35-38 lbs, and EVO16g at ~42-43 lbs. I would expect this to end up in the low 30s, but that's pure speculation as I have no personal experience with one. If it is still using the T25 hotside your biggest problem will be turbine housing pressure and WG blowing open.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-22-2006, 03:13 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
I know someone who might be selling smim's . Someone offered me $400 to build him so it looks like it's on to round 2, me vs steel.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 05-22-2006, 11:16 AM
blk_srt's Avatar
What are you doing with the one that you already made?
Mods:
Old 05-22-2006, 07:36 PM
NateS's Avatar
Okay, as for logging software... I have a palm pilot with palmenstien installed on it and I have my afc for tuning. I do have arp head studs installed so I am not to worried about that. I am suprised to hear the T28 can reach over 30psi. Now that I know this I probably wouldn't take it past 25-28. It all depends on when I get everything installed and how it runs. I think I can get the basic tuning done so it is drivable but, I will probably need some help with the fine tuning. I would be happy to see 280whp from this turbo. Oh and I will be running this baby on pump gas most the time. It is going to be a light daily driver along with a weekend warrior so, pump gas will be used(93 octane).
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 05-22-2006, 09:36 PM
AF - Advisor
Over 30 lbs/min, not psi
Kevin Jewer
Old 05-22-2006, 10:36 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
95 Talon TSI AWD
97 Eclipse GST
Old 05-22-2006, 10:58 PM
Thor06's Avatar
Jizzed In My Pants
It is pretty amazing how many people think PSI means airflow. Its really hard to talk to anyone besides like 4 people in my town about cars because none of them have any fuckin clue what they are talking about. On of my good friends is a Honda-turned-Toyota guy. Hes a pretty good guy and knows some of what hes talking about, but man, he and basically everyone else I know here dont realize that a t25 and a t67 are going to flow different amounts of air at a given pressure.
Old 05-22-2006, 11:16 PM
I don't think half the kids in my town know what a turbo does. One kid bought a "NOS" kit for his car but didn't hook it up to the motor, just the purge kit. He just drove around spraying it out all over. And then he just put in CO2 when he wasted all the "NOS" (or so he called it.) What a damn moron. And yes, he does drive a honduh.
95 Talon TSI AWD
97 Eclipse GST
