Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 05-21-2006, 09:10 PM
csparks78 csparks78 is offline
Question Help with body lift
OK here is the scoop.... One of my buddies, new to wheelin and Jeepin' bought a 99 Tj and he got a 3" body lift off ebay.... the prob. is he doesn't have a susp. lift to back it up. This will look funny as hell with only 33's right?? I'm trying to talk him out of it until he gets a susp lift too, but being the kind of guy I am I will help him put it in if he decides to go with it. What kind of tools/jacks do you need to install it, and are they hard to do?? I haven't done one yet. Thanks for the help!!! Cliff
Old 05-22-2006, 09:32 PM
o|||||||o o|||||||o is offline
Send a message via AIM to o|||||||o
Re: Help with body lift
A 3" body lift on a TJ is a bad idea. A 1" is the most I would recommend. A 3" is going to be a PIA. There are a lot of little things getting in the way that make it tough. On top of that they look like CRAP when they have that much body lift!
2004 Jeep Wrangler Rubicon (Modified a lil' bit)
2003 Honda VFR 800 (All stock w/ABS, just like Honda built it)
2001 Ford Crown Victoria Police Interceptor (It looks like a cop car because it is one)
Old 05-22-2006, 11:36 PM
I agree!!! Its not me thats doing it, and I think it will look stupid especially without a suspension lift to go with it, but if he decides to go with it - Ill help him, do you know what Ill need for it??? Any special parts, tools, big hammers lol ???
Old 05-23-2006, 10:03 AM
Kuhn's Avatar
Kuhn Kuhn is offline
Send a message via AIM to Kuhn Send a message via Yahoo to Kuhn
I'm new to Jeeps and all I know if from what I've read in this forum... Pretty much everybody agrees that a 3'' BL is a horrible idea, but not only because it looks funny. It would require that lines be extended and stuff... basically it's a lot more difficult than a 1''BL... Try to talk him into getting a 1''BL and some 2'' Spring/Shock spacers. I know this isn't what your looking for, but it's my I think it'll be difficult to find someone that's put on a 3'' BL.
'98 Eclipse RS
ENGINE: Twin Ceramic Ball Bearing T3/T4 with ceramic blades (20G for sale!), FMIC, 3'' Intercooler Piping and Down Pipe, Dump after Down Pipe, Walbro 255 FP, 450cc 4G63 Injectors, Greddy E-Manage, TurboXS DSBC (4/7psi for now).
SUSPENSION: Sustec Front and Rear Lower Tie Bars, Suspension Techniques Front and Rear Sway Bars, DC Sports Front and Rear Upper Strut Tower Bars, Eibach Pro Kit Springs, KYB AGX Adjustable Struts, Polyurethane Bushings Everywhere.
Old 05-24-2006, 10:43 AM
Kuhn's Avatar
Serch this forum for " 3'' Body Lift ". Somebody did this and had an issue... Give it a look.
'98 Eclipse RS
Old 05-24-2006, 07:03 PM
wilwith1l's Avatar
wilwith1l wilwith1l is offline
I've done two 3" BLs(not on my rigs). 1 YJ and 1 on a 1978 Chevy Luv(which turned out to be the only time i will suggest a 3"BL. It's super easy if you get a complete kit. All you do is unbolt the chasis, and (in sections) jack it up, throw in spacers and bolt it down. Then you extend your lines & fuel neck, drop your radiator, adjust your T-case shifter, and you might need the sawzall to use some gears. Don't forget the gap guards, and only use Grade 8 bolts, no matter what the kit comes with.
