Go Back   Automotive Forums Car Chat > Nissan > Older Pickups
Old 05-21-2006, 07:55 PM
ttfox88 ttfox88 is offline
wont start no spark.
i have a 1989 seV6 kingcab and it was working fine when i parked to go to the store when i came back to turn it on it wont start it cranks but it doesnt start. i figure i ran out of gas but that wasnt it then , checked for spark and the cables were bad so i changed them. along with distributor cap. no spark bought a new coil and coil module didnt spark , got a different distributor no power. now it cranks u know shus shsus shsushsu but thats it any one knows what else could it be.?"
Old 05-27-2006, 04:30 PM
tomas hayden tomas hayden is offline
Re: wont start no spark.
check the fusible links ..
Old 06-02-2006, 05:50 PM
marc780 marc780 is offline
Can you turn the distributor rotor by hand? Shouldn't be able to - Here's a long shot thing that happened to me, TTfox. I went around a corner right after having it smogged, and i heard a "snap" sound from engine somewhere, and the engine died. So it cranks, but no start-no spark.
So i checked everything in the book and then i removed the dist cap. And noticed the rotor spun freely! So it turned out that the oil pump shaft was broken (since it also turns the distributor).
What caused the shaft to break? I determined the dist. hold down bolts were stripped, so the distributor could wobble just enough to break the shaft. I know for certain the threaded holes were fine before i brought it to the smog station. So it was done by the neanderthals at the smog place! I dont know why they did this, they refused to adjust anything in the first place even so i could passthe #@$%&*!!! smog test and i had to come back 3 times!
Anyway, see if you can turn your rotor by hand, if you can do it you have the same problem, so change the shaft.
And in the unlikely event that this turns out to be your problem, PM me or just reply this message and i will give you more info on doing this fairly easy job.
Old 08-16-2006, 12:50 AM
it was the ecm go figure
