Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 05-21-2006, 04:34 PM
RacinDave RacinDave is offline
Exclamation i'm havin trouble
my 86 2.9 bronco 2 will hit 30 km/h and start spiting and sputtering and it goes crazy anyone have the answer?
Old 10-02-2006, 10:09 PM
wannabebronco wannabebronco is offline
Re: i'm havin trouble
Check/replace plugs and wires, then? Timing, air intake.
Old 10-14-2006, 12:46 PM
Exclamation Re: i'm havin trouble
i did that and still the same some people say that the oxygen sensor might be it ?
Old 10-15-2006, 09:28 AM
rhandwor rhandwor is offline
Did you change your fuel filter? If you tuned it up are you getting any codes.
Also check your air filter. I have found many people use cheap plug wires and I have had to remove the wires and recrimp the ends normally the plug end.
I have noticed some auto zone and advanced employees say not to gap the plugs which isn't correct.
