Old 05-21-2006, 02:38 PM
blacksmith76 blacksmith76 is offline
Unhappy stripped oil pan?
89 s-10 blazer 160000 miles. I noticed oil leaking from the drain plug found out it was loose, it would not tighten up. So I used the next size up still too loose and it seems like the threads are gone. Is there any other option to avoid replacing the whole thing? If not how difficult of a job will this be and will I need any special tools. Thank you for viewing this thread.
Old 05-21-2006, 04:25 PM
OverBoardProject OverBoardProject is offline
Banned
Re: stripped oil pan?
Try tapping it for the next size that will fit. If it doesn't work you'll pretty much have to figure out how to pull the oil pan (usually takes lifting the motor) and get it fixxed.
Old 05-21-2006, 04:35 PM
Talking Re: stripped oil pan?
thank you! I think I got it fixed. Probably be the last time the oil ever gets changed on that blazer! LOL
Old 05-21-2006, 05:21 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
Idk but when this happened on my 91 they put the next bigger size plug in with lots and lots and lots of loc tite and that solved that issue but the rear main still leekd at the time.
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 05-21-2006, 05:40 PM
Banned
And Shawn took care of the oil leak by dropping in a V8
Please contact him for some of his parts when you do the same thing
Old 05-21-2006, 08:07 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Take your stripped/loose plug/bolt into Napa. They'll sell you the next larger size Self-tapping plug, $4.00 tops.
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
Old 05-21-2006, 09:47 PM
My rear main seal leaks as well. I only put about 4000 miles a year on this blazer so a quick cheap fix works well.
