Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-21-2006, 01:40 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question Spring Install
Maybe I'm blind or just stupid, but is there a tutorial on how to install springs somewhere?
I guess what my question is is can I uphook the strut from the strut tower, lower the whole arms, use a spring compressor, and pull the spring out? Or do I have to take off the whole shock? Will it slide over the top of the strut itself? Thanks!
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 05-21-2006, 01:56 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: Spring Install
you have to pull the whole thing out, compress the spring, and then pull the mount off and reverse the process
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 05-21-2006, 01:59 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Spring Install
It's alot easier if you take off the whole thing and just compress the spring out of the car. Otherwise you're battling with it inside a confined area.
95 Talon TSI AWD
97 Eclipse GST
Old 05-21-2006, 08:40 PM
97gs-t teamrtv 97gs-t teamrtv is offline
Send a message via AIM to 97gs-t teamrtv Send a message via MSN to 97gs-t teamrtv Send a message via Yahoo to 97gs-t teamrtv
Re: Spring Install
if you dont already have a spring compressor, i suggest just taking the whole assembly out (for all four) and taking to a shop. i paid $30 for them to mount on new shocks and springs onto my existing strut tower, bolted them back in and i was good to go. $30 and they do all the work or pay aroung the same for a tool you will use once on your car.
97 gs-t: Guages: boost, oil pressure and temp, water temp and volts. AEM cam gears, short throw shifter, hks ssqv, injen intake, brembo drilled rotors, akebono ceramic pads, sportline springs & koni ajustables, Strut bars: front, rear and lower rear tie bar. Evo III manifold and o2, megan downpipe, Apexi N1 catback, 16g, 190 fuel pump and FMIC.
Old 05-21-2006, 08:57 PM
Re: Spring Install
I just borrowed some from a local tire shop. Cost me $0.
95 Talon TSI AWD
97 Eclipse GST
Old 05-21-2006, 09:01 PM
Re: Spring Install
Damn you beat me then. oh well
Old 05-21-2006, 09:19 PM
blk_srt's Avatar
Re: Spring Install
parts stored loan them out to
Mods:
Old 05-21-2006, 09:27 PM
david-b's Avatar
Dave is THAT guy
Re: Spring Install
Yeah... Autozone rents them out. You pay up front, but then get your money back when you bring it back. Does anyone have pics of the process or a tutorial? Pics talk more than words do. ;-)
Thanks guys.
75 Monte Carlo
Old 05-21-2006, 10:06 PM
Black97GST Black97GST is offline
Re: Spring Install
I have changed my springs twice and have never used a spring compressor. Just lift the car off the ground. Loosen all the bolts on top including the one on the strut rod. then loosen the one in the wheel well. Dissasemble the strut/spring assembly, re-assemble it with the new spring and or strut. Install the assembly then lower the car. Weight of the car makes a great spring compressor. Its been fine for me.
Old 05-21-2006, 10:11 PM
david-b's Avatar
Dave is THAT guy
Re: Spring Install
Is that even safe? lol. Where is the bolt on the strut rod?
So basically, I can lift the car, undo the bolts uptop, drop the assembly and pull the spring out, right?
75 Monte Carlo
Old 05-21-2006, 10:44 PM
blk_srt's Avatar
Re: Spring Install
OK the right way to do it is jack the car up, take off the wheel, take off the two pinch bolts on the knuckle that hold the bottom of the strut on and then take off the 4 bolts or whatever on the top for the mount and the whole thing will drop out. Then you need a spring compressor and compress the spring and take off the one big bolt in the center top of the mount and then verything will come apart and then reverse it
Mods:
Old 05-21-2006, 11:32 PM
david-b's Avatar
Dave is THAT guy
Re: Spring Install
ahh. makes sense then
75 Monte Carlo
Old 05-22-2006, 12:10 PM
Fallenfantasies Fallenfantasies is offline
Re: Spring Install
Make sure the springs or coil overs stay on the strut whenever you are releasing the jack or it coudl cause u some trouble. Watch all the springs settle by letting the jack down really really slow
Old 05-22-2006, 01:04 PM
Re: Spring Install
And then get us some pics of the finished product.
95 Talon TSI AWD
97 Eclipse GST
