Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-21-2006, 01:17 PM
GSXracerGuy GSXracerGuy is offline
Send a message via AIM to GSXracerGuy
Broken Door Handle Again
The driver's side door handle broke off in the winter, and since then I have been opening my door through the passenger side. I have finally decided it is time to fix the door handle. I have a new one ordered..so I was wondering, since I am sure I won't be able to figure it out on my own, does anyone have a manual lying around that would have the door handle in it? I have a Chilton's manual but it's 600 pages of info only on vacuum tubes that are in the engine...
Or if you don't, let me know of a site with a number of manuals for different things because I can't find one.
Thanks
1995 GSX M/t 87k[IMG][IMG]
Gotta lotta work to do.
[IMG][/IMG]
Old 05-21-2006, 02:35 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Broken Door Handle Again
Replacing the door handle isn't all that terribly hard. Just pull off the interior panel and there are some bolts holding it on from the backside of the door. If you look at it long enough you'll figure it out. I don't think there are any manuals out there with door handle instructions in them. Check the Vfaq or Tuners for a writeup.
95 Talon TSI AWD
97 Eclipse GST
Old 05-21-2006, 04:49 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Where did you get the handle from? I was checking the dealer and they are like $55 but that's painted so i think i might just get one of those.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 05-21-2006, 10:34 PM
Nah man get it off e-bay. There are some on there for like 33 bucks that are already painted, and also ones that are carbon fiber so it won't break off when it is -48 degrees outside like when mine broke
[IMG][/IMG]
Old 05-21-2006, 11:12 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
That makes no sense.
Do a search, there are a bunch of threads I posted a link to a write-up in and I don't feel like finding it and posting it for like the 5th time.
I got my handle off ebay from a dealer for $60 shipped and it was painted the stock black color.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 05-21-2006, 11:28 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
does anybody have the link for the stainless steel ones that soembody used to make?
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 05-21-2006, 11:38 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Good to see you 1stGenRocks...
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 05-22-2006, 03:25 AM
ez1286's Avatar
I did a quick search and found nothing but i think i'll look into making them. I don't think it would be very hard.
Old 05-22-2006, 04:43 AM
I think the link for the stainless ones is somewhere in the Tuners tech articles.
95 Talon TSI AWD
97 Eclipse GST
