Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-21-2006, 01:13 PM
Ramblin Fever Ramblin Fever is offline
FWIW - Napa Gold 1334 oil filter's
for our Rodeo's seem to be the best quality of all the filters I've seen around.
Cleaning out cupboards in my garage, I have a habit of buying 2 of all little things, and have a lot of extra Isuzu oil filters sitting around, had been using OEM for a while, but there were a few times I tried others.
Anyhow, out of the one's I have sitting around = Motorcraft, Bosch, STP, ACDelco, Puralator Premium plus, it looks like the Napa Gold comes off as the better quality of the bunch, with Motorcraft and Puralator built pretty good as well.
I have a Motorcraft filter on the truck now, and I do like it - no ticking; and will keep the Puralator and the Gold. But have no use for the STP and ACDelco, made the engine tick horribly.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 05-21-2006, 01:19 PM
pharm_rodeo's Avatar
pharm_rodeo pharm_rodeo is offline
Re: FWIW - Napa Gold 1334 oil filter's
Which is more cost effective b/w OEM and the Gold?
Old 05-21-2006, 04:06 PM
rodeo02 rodeo02 is offline
Yep. I used the carquest premium version, which is the same WIX filter. The OD of the can is slightly larger and longer that other brands + the can is very sturdy and crush resistant. Nice filter if you extend your drain intervals. I wouldn't waste such a nice oil filter for 3-4K drain intervals.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 05-21-2006, 04:27 PM
surferfletch surferfletch is offline
I have used Purolators on my 3.2L with good performance. I might switch to NAPAs version. Most guys on the Jeep board I frequent use a Wix filter, too. I had been using Motorcraft. I can easily deform the outer canister of the Motorcraft, but it's internals seem more than adequate.
Old 05-21-2006, 08:23 PM
Joel
Actually, what I'm gonna do, is just change the filter every other oil change; the oil at 3k is still a real light brown color, in which case, I'll probably extend the oil out to 4-5k intervals and the filter to 8-10k intervals.
With all of those real short oil/filter changes there for a while, must've done some good, as the oil is still REAL clean at 3k miles. Unlike my Toyota's oil that turns black by 2k miles.
OEM oil filter is about $9; Napa Gold is $8 - so not much difference there.
1997 3.2L V6 Rodeo
Old 05-21-2006, 10:08 PM
Canucklehead Canucklehead is offline
Send a message via MSN to Canucklehead
Around here it's only $6.56 for Napa Gold and $6.00 for OEM. Weird.
2000 VW New Beetle TDI
2007 Honda CR-V
Old 05-22-2006, 01:39 AM
anthonyn anthonyn is offline
FYI. The 1344 is the oversized version of the 1334. Been using it for the last 3 oil changes. Works well.
check out www.fleetfilter.com. Should come out way cheaper than 8 bucks.
Old 05-23-2006, 12:10 AM
df2000 df2000 is offline
Send a message via AIM to df2000 Send a message via Yahoo to df2000
Contrary to Ramblin experience last 5-6 years I use exclusively supertech ST2808 and AC1127, both older style with round spring pressure relief valve and engine no tick at all. I don't like Purolator, I rounded couple of them during removal, metal too flimsy.
