| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Recently i've been getting hesitating starts. it won't start first go. a lot of the time. it cranks and trys to start, but just chokes and stupbles to a stall. second go it starts fine.
when this happens stumbles on reving. like if i'm in nutral the rmps go down before they go up. and it like almost stalls. once its warm it runs like a champ. or if i run just down the street it will be good. it i drive for a bit, park. let it sit 3 hours it will start and run fine. it got way worse the other day when i had 2 days off and didn't drive. electrical? battery is 2 years old, but a 3 year battery. plugs new, wires who knows. fuel filter new. ideas?
![]() Something new is coming... |
Re: hesitating starts, stumbles before warm
I'm thinking something like the IAC or TPS sensor. It sounds like something isn't reading right.
I don't think it would be the tps because the tps is only for emissions. I think the iac is possible but i think the fuel system is more likely the problem. If you're car cannot maintain fuel pressure while the car is off it may be trying to get fuel to the engine it it has not been on it a while. I'm thinking this is the cause because you said it was worse the longer it sat.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff. http://www.ratemydsm.com/member/ez1286/?member=ez1286
Since when is the throttle position sensor for emissions?
unplug it see what happens, nothing, it is useful for logging but that it.
The TPS houses the closed throttle position switch, which controls the IAC based on a high and low voltage signal. It's used more than for just logging. And I don't see how it deals at all with emissions.
I'm feeling lazy right now but i'll find th link later. I'm not arguing i'm just saying it doesn't help the performance nor driveability of the car i unplugged mine a few months ago and it has done nothing.
Maybe yours never worked in the first place? I don't know but any car that I've ever dealt with needed the tps to run/drive normally. I'm not arguing, I just stick firm to my knowledge/opinion
Might be a vac leak. My buddy Mike's Olds had the vac hose on the MAP sensor (I think, thats just what he told me) was cut and it stumbled around and idled funny until it was warm.
car sat alll day sunday parked. started right up no problems. sat all night outside got down to about 40. ever so slight start up hesitation, and a little hesitation on acceration.
i had a simualr problem the winter before last. new spark plugs took care of it, and last winter it was fine. now its doing the same thing in the cold. as it gets warmer this week i'll be able to tell if its outside temperature that causes it.
Mine did the same thing when in cold weather. Took many tried to get it to turn over and stay on. I replaced the TPS and the IAC, and it has worked fine ever since. The IAC is more than likely the problem though. My car refused to run without the TPS plugged in FYI. IDK why.
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
umm are the TPS and the IAC expensive to replace?
![]() Something new is coming... Last edited by TreeFrog; 05-23-2006 at 06:36 AM. |
I believe the IAC is ~$100 (give or take 10 depending on where you go) and the TPS i'm not sure. Check ebay.
