Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-21-2006, 12:49 AM
kbasham03's Avatar
kbasham03 kbasham03 is offline
dsm clutch problems
i have a 95 talon tsi and the other day i was crusin on the highway about 70mph and i shifted into neutral, then i went to put it back into gear and it would not go, i coasted into the shoulder and still couldnt get it into gear. It makes this squeeling noise when i push down the clutch pedal and it vibrates. I tried putting the car into gear with the car not running and i got it into 1st and started the car and the car pulled forwards like the clutch was still in gear even though i had the clutch pedal to the floor. i put it back into neutral and my car rolled back and made a clunk noise and the clutch felt fine so i put it back into 1st and was able to pull forward a little bit but then it heard a grinding noise like the clutch was half engaged. I dont know what is wrong and i dont feel like pulling the trans. I got it towed home and checked the slave cylinder and it still moves fine. I called around and asked people and ive heard anywhere from its the throw out bearing, to the clutch disc came apart ( which i dont know because it has a fairly new act 2100) to it may have crankwalk, so if anyone thinks they know whats goin on with it please let me know thanks
Old 05-21-2006, 01:46 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: dsm clutch problems
Well i can say from experience that it really could be the act clutch. I'm assuming you have the street disc. I had mine break a while ago. Here's a link with some details. http://www.automotiveforums.com/vbul...=why+act+sucks
It was very similar to your problems.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 05-21-2006, 09:49 AM
kbasham03's Avatar
im probably goin to rip the tranny out today, and if one of those springs is gone 2morrow i will call act and bitch at them
Old 05-21-2006, 11:23 AM
steviek's Avatar
steviek steviek is offline
I had the same problem its your clutch... I guess thats a bit of a relief for u since its not your tranny. BUt yea act 2100 did that to me. Then I bought 2600. And Since then I've switched off of act and now am running exedy. My only problem with exedy is its sooo violent it grabs my clutch the second I let off of the pedal even in the least. Great for racing not so great for daily driving (fortunately most of the time I combine the two )
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 05-21-2006, 11:55 AM
kbasham03's Avatar
what were your exact symptoms
Old 05-21-2006, 04:56 PM
ez1286's Avatar
I had the same exact problems with my clutch.
btw steviek, the act clutches both have the same disc unless you go to the six puck disc. So the 2600 # wouldn't make any differnce it might have made it more likely beacuase the increased pressure on launching.
Old 05-21-2006, 09:17 PM
kbasham03's Avatar
would it be safe for me just to replace the disc?
Old 05-21-2006, 10:13 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Check everything else. If it all still looks ok, I'd just get a new disk. Disks arent all that expensive, but the rest looks bad I would for sure get new stuff.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 05-22-2006, 03:26 AM
ez1286's Avatar
I got a new act disc it was like $150 or something. At the time i didn't have the money to do a whole new clutch.
Old 05-29-2006, 08:47 AM
kbasham03's Avatar
I pulled the trans yesterday and sure enough the spring broke out of the disc
