Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-20-2006, 11:02 PM
TreeFrog's Avatar
TreeFrog TreeFrog is offline
Send a message via AIM to TreeFrog
Question Low oil pressure
Okay my stock oil pressure guage reads right on the "L" when idleing, and just a bit above it while running. I have no leaks, just got an oil change. oil light never comes on.
any ideas? probably the oil pump, or sensor. Is this a huge issue? how expensive is replacing the oil pump?
Something new is coming...
Old 05-20-2006, 11:05 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: Low oil pressure
Try testing it with a mechanical gauge because the stocker can be inacurate. Also oil pressure is made by the engine bearings not the pump
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 05-21-2006, 03:41 AM
TreeFrog's Avatar
ummm bearings!!! oh shit!
PS. I did some searching around the great DSM talk forum. seems most people just ignore the stocker gauge. but the oil light is accurate and if it comes on, pull the over the car, turn it off and push.
others have mentioned the bearings, oil pressure sensor/sender unit thingy, and the oil pump. you're right best thing to do is get it tested with a real gauge. if it reads fine, then ignore the gauge.
Old 05-21-2006, 10:58 AM
blk_srt's Avatar
correct
Mods:
Old 05-21-2006, 11:15 AM
MexRocket's Avatar
MexRocket MexRocket is offline
bah oil pressure gauges =P
I should probably get that, my c2 boost gauge is blinding.
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 05-21-2006, 02:39 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
You probably should get that checked out before you drive the car much more. If it is a problem and you catch it before it ruins anything, you could save yourself a rebuild. Replace the oil pump is just one step more than doing a timing belt job. You have to pull off all the same stuff, but then you also have to remove the oil pump too and install a new one. Then put in a new front oil seal, then just continue the rest of the timing belt job. Don't quote my exact words though, that's just a quick overview.
95 Talon TSI AWD
97 Eclipse GST
Old 05-21-2006, 02:43 PM
blk_srt's Avatar
I dont think its the oil pump though considering that doesnt create the actual oil pressure just volume.
Mods:
Old 05-21-2006, 02:45 PM
But if it's not flowing enough volume, you'll get low pressure.
EDIT: I'll explain myself a little better. To get pressure, you have to be flowing more than enough volume than what is needed to create any certain pressure at a given spot. It's like trying to pump 50 gallons of water through a hose. If you want to pump a volume of 10 gallons/min, you'll have more pressure than if it's only pumping at volume 5 gallons/min. Therefore, if the pump normally pumps so much oil at a given rate, then you will have normal oil pressure. But if the pump can't flow the amount needed, then it won't create the pressure needed either. I hope you understand what I'm trying to say.
95 Talon TSI AWD
97 Eclipse GST
Old 05-21-2006, 02:57 PM
blk_srt's Avatar
That is true I've seen more bearing failure than low volume causing low pressure though.
Mods:
Old 05-21-2006, 02:58 PM
I know but if the pressure is way lower than normal, than something isn't right. He needs to hook up a real gauge like you said.
95 Talon TSI AWD
97 Eclipse GST
Old 05-21-2006, 03:01 PM
blk_srt's Avatar
I have a feeling its just a bad sender. My stock gauge reads 0 all the time, some times it scares me a little untill I relize I unhooked it to hook up my autometer
Mods:
Old 05-21-2006, 07:50 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Mine is broken too. POS stock guages. Eventually I would like to replace everything with autometer stuff. I probably wont though, thats like $800 is guages I can put into a stroker or something.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 05-23-2006, 05:38 AM
TreeFrog's Avatar
well i've been told i can be at 12psi on idle and still fine under the shop manual. and that if it was too low i'd get a light. and basicly i have no issue. does this sound correct?
Old 05-23-2006, 08:49 AM
As long as you're not getting a light you should be fine. But you should probably hook it up to a gauge to at least see what you're actually running.
95 Talon TSI AWD
97 Eclipse GST
Old 05-23-2006, 11:17 AM
blk_srt's Avatar
the spec is 11psi at idle but you should verify it
Mods:
