Old 05-20-2006, 09:43 PM
stapletonr stapletonr is offline
Send a message via Yahoo to stapletonr
Fuel Guage 92 GV
I hope im not out of line here but my wife owns a 92 Grand Voyager, 3.3, auto, power locks and windows. The problem is the fuel guage. Sometimes at startup the low fuel light will come on and the guage will read empty even with a full tank. Other times while driving down the hiway everything is fine then all of a sudden the low fuel light will come on and the guage drops to empty, even with a full tank. Then sometimes the light goes off and the guage returns to normal.... A Short?? Where do I start trying to find and fix this royal pain?
Thank You.
When I said I hoped I wouldnt get in trouble, I meant by putting this post out by itself as I didnt see any others like it.... Now I assume that finding a starting place is wherever I think I should start.... Thanks.
Old 05-24-2006, 11:59 PM
vamc's Avatar
vamc vamc is offline
Re: Fuel Guage 92 GV
Sending unit is bad.
Old 05-25-2006, 02:42 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
stapletonr - You're not alone. Mine's been doing that off and on for a year. Nothing to do but either live with it or change the sending unit.
Old 05-25-2006, 07:56 PM
vipergg vipergg is offline
Do to some poorer quality gases sulfur deposits can build up on the sensor and cause erratic readings you can sometimes use a good gas additive to fix this . I would try running soemthing like Techron thru a couple of tanks and see what happens , if that doesn't then replacement of the pump an sensor is proabbly required . Read http://www.chevron.com/products/prod...ate_plus.shtml
Old 05-25-2006, 08:39 PM
Thank you all very much. At least the tank should be easy to drop.
Old 06-02-2006, 05:55 AM
Would it be a correct assumption that there is no access without dropping the tank?
Old 06-06-2006, 11:32 PM
OK so I replaced the pump, not easy but got it done. Fuel gauge still not working. Is there a relay or something under the dash that could be at fault?
Old 06-07-2006, 01:32 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Oh no! I'm pretty sure the fuel gauge sending unit is seperate from the pump. If you didn't you need to change the sending unit as stated. I hope you goofed and said pump instead of sending unit.
Look here: http://www.makeitmopar.com/ They want $61.
Old 06-08-2006, 11:01 PM
Well I found out that the sending unit is seperate however it is connected to the pump and now both are brand new. I also found out that if I bump, OK smack, the dash to the right and below the steering column the gauge works. This is in the area of a computer? ECM? Two plug ins, both multi wire, one blue and one white. Small metal box....Could this be the problem? What exactly is this box and can it be replaced with one from a wrecking yard? Im willing to try just about anything short of taking it to the dealer.....Ok since nobody will answer that part how about this...Is there a relay dedicated to the fuel gauge? If yes where might it be located?
Last edited by stapletonr; 06-28-2006 at 07:08 PM. Reason: No answers to first part question posed
Old 07-05-2006, 06:49 PM
Surely somebody out there has a suggestion?
Old 07-05-2006, 09:41 PM
vamc's Avatar
I still think its a sending unit or the connection to the sending unit.
Old 07-06-2006, 06:22 PM
Well I will drop the tank again, as soon as its low enough on gas, and check the connections to see if I have them where they belong and correctly. Thank You
Old 07-07-2006, 12:20 AM
earlyrizr earlyrizr is offline
does any other guage on the dash act up as well?If so there are usually bad solder joints on the board that need to be re-soldered.
Old 07-07-2006, 12:30 PM
No sir. Thhere are just two gauges, fuel and temp. The fuel gauge is the only one that doesnt work. Like I have said, it has a new fuel pump/sending unit.
