Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 05-20-2006, 03:13 PM
95_acr_coupe 95_acr_coupe is offline
Send a message via AIM to 95_acr_coupe Send a message via Yahoo to 95_acr_coupe
Angry wont turn over, need help with gauges too
my car is a 95 neon coupe with a 98 dohc motor, computer and wiring harness and it was running great and all of a sudden wont turn over at all, ive checked everything, the fuses, relays, wiring and i know that the starter is good because i just recently put it in. second problem, i bought an autometer 5 inch tachometer, air/fuel ratio, water temp, and oil pressure gauges and am having trouble with them, the tachometer always jumps to where the shift light is set but sometimes works fine, second issue that im having is that the air/fuel gauge stays lit up all the time, even with the key off, ive hooked the ignition lead to 3 different switched ignition sources and i keep having the same problem, any help would be great. thanx for your time
I NEED AN H22A SWAP KIT FOR A 3G LUDE!!!!!!!http://www.cardomain.com/id/shadowslayer0666
Old 05-20-2006, 09:51 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: wont turn over, need help with gauges too
Checked you battery connections and grounds?
Old 05-21-2006, 12:42 AM
ss5wil ss5wil is offline
Check your trans. shifter cables if they're gone you'll have to get new ones
P.S. dealer items only
Old 05-21-2006, 03:49 AM
my trans cables are good, i just put them in a few months ago and havent driven the car yet with them. also i checked all of my grounds, wires, fuses, battery terminals and clutch sensor and nothing is wrong with them, i have been having tons of problems with the starter and battery wires lately tho, ive changed them like 3 times in the last 3 months. my car is also throwing a trouble code 12 which is something to do with power loss to the ecu over the last 50 key on cycles. im also throwing codes 21 31 and 35.
Old 05-27-2006, 09:34 AM
HPNOTIQracing HPNOTIQracing is offline
did you find the problem
