Old 05-20-2006, 09:07 AM
wilfie27 wilfie27 is offline
rear diff pinion seal.
95 Blazer LT 2 dr/2wd, 186,000 mi.
Two weeks two problems. Last week I had to replace the fuel pump and now I noticed a vibration in the rear end upon accelration. A co-worker following me home the other day said he noticed a puff of smoke from under the vehicle as I was going up hills.
This morning I looked under the diff and saw a leak from the front pinion seal. I have never tore into a rear end on a blazer before. I was wondering if I need any special tools before I start or if anyone has any advice before I get myself into a pickle.
I feel I was pressing my luck last week by cutting a hole in the bed to change the fuel pump instead of dropping the tank but that seemed to work out ok. Side note....I got the fuel pump for $75 plus the strainer $7 ( a lot for a pump )
Old 05-20-2006, 09:19 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: rear diff pinion seal.
That is cheap for a newer type fuel pump some run up to 500$ us or more.
The seal pops out and can be put in with a driver.
But Pinions bearings need the preload set.
Most of them will have a crush sleve in there.
Get some good repair info on it or here is a link that may help.
http://www.differentials.com/install.html
MT
Let us know how it goes.
MT
Old 05-20-2006, 01:33 PM
SComp23 SComp23 is offline
I was told that unless you have done this before or have a very good knowledge of how to do it you need to be verrry careful, over torquing the pinion will cause excessive wear on the bearings and basically make you lose your rear end.
Old 05-20-2006, 02:05 PM
MT-2500's Avatar
AF - Advisor
10-4 on that
That is why I posted the link on how to set it.
check this link for torque specs and how to.
MT
MT
Old 05-21-2006, 07:26 AM
Funny thing...while getting supplies I knew I needed a 1 1/4" socket for the pinion nut, all they had was a 3/4" drive...socket $6 half to three quarter adapter $25, the adapter was a Blackhawk though. Went to another parts store and found a half inch drive.
After pulling the rear cover I was relieved to see nothing on the magnet but the fluid was a little low and awfully thin. That pinion nut was a bear to come off, (liquid wrench+18" breaker bar+leg=nut off) A bucket-o-fun in a gravel driveway. BTW I did mark the origional setting first with a paint marker.
Seal out of the way bearing looked fine pinion shaft doesn't move. I was told there was a crush sleeve in there but I found nothing but the bearing which looked fine and the shaft didn't wiggle.
Another funny (not ha-ha but Steve Buscemi funny) thing, when I pulled the yoke off the grease on the splines smelled like rubbing alcohol???
I used roughly 2 1/2 qts of 140/85 to fill it up, the book doesn't give you a capacity for the rear diff. Another thing you would think they would put to fill hole on the other side with the tailpipe being there.
The vibration isn't as bad as before but with that many miles and the work and money involved I'll live with it.
Old 05-21-2006, 09:31 AM
MT-2500's Avatar
AF - Advisor
You need to be sure you set the preload or your rear end willl not last long.
Go to the site I posted and it tellls how to do that.
MT
MT
Old 05-22-2006, 11:58 AM
joeuser742 joeuser742 is offline
I had the same problem with a vibration, didn't know what it was until a few days later, then bang, I was missing a few ring and pinion teeth. I ended up getting really lucky and pulling a used one from the junkyard that had been recently rebuilt for $20.
You might want to get that fixed or your going to get stuck somewhere and it will probably cost more.
1998 Blazer 4WD 4.3L 118,000miles 4dr
Repairs
--rear main seal, u/l ball joints, pitman/idler arms, i/o tie rod ends, control arm bushings, motor/trans mounts, oil relocation lines, door pin bushings, water pump, ring/pinion.
--Bad ABS ground, loose connection blower motor, repaired pulse board.
Mods/upgrades
-Throttle plate mod.
1999 Ford Windstar SE 3.8L 160,000miles
Repairs
--P171/P174 procedure, loaded control arms, tie rod ends, shocks, struts, springs.
