Old 05-20-2006, 07:51 AM
JPA70 JPA70 is offline
Snythetic Oil Question
I have a 1997 F-150, 1997 Taurus, and a 2001 Grand Prix. The Fords are over 120,000 miles each and the Pontiac is at 81,000. I have owned all 3 since their very very early days (but not new). My oil (always Castrol GTX) has never been in a block longer then 3500 miles ever. I ran AmsOil in the F-150 for awhile and ran many more miles on it then. All 3 are in top notch running condition, no smoke, no leaks, and all sound great.
My question is with this many miles on the engines, is it still worth the expense of using snythetic oil in them or is what ever wear is the there is there so its a waste of money?
Thanks,
Jeff
Old 05-20-2006, 07:14 PM
ModMech's Avatar
ModMech ModMech is offline
Re: Snythetic Oil Question
Jeff,
Wether or not to use synehttic oil is not really dependant on the mileage or age of the vehicle, but of it's condition and how long you plan to keep it.
If you keep you vehicles the "normal" 3 years or so, then I would say that synthetic lubricants are most likely not worth your trouble.
If you do like we do in our home, and buy good used vehicles and drive them until it's time for the crusher, then yes I feel they are a real benefit.
That not withstanding, you can save up to 5% on your fuel use, and over the years synthetics actually cost LESS because there is absolutely no need to change oil every 3,000 miles. 7500 mile intervals with a GOOD synthetic oil (like Amsoil) are more than adequate for most people.
Old 05-21-2006, 11:20 AM
Thanks for replying. We do drive them until they get to a point that no yu can but thats not from lack of care, just age. I have no problem spending the time and money to keep them running right (hense the 3000 mile oil changes ). I will start using snythetic at the next change.
Thansk again,
Jeff
Old 05-21-2006, 12:20 PM
ModMech's Avatar
You are welcome, glad to help.
Old 05-21-2006, 12:46 PM
wafrederick wafrederick is offline
Banned
Do not put synthetic in the newer engines or the lifters will rattle.My neighbor's wife did that,changed to synthetic in a 1998 or 1999 S10 and the lifters rattled like crazy.She did drain out the synthetic out and put in what is recomended,the lifters quieted right up.Put in what is recomended.
Old 05-21-2006, 04:18 PM
ModMech's Avatar
I'll call BS to that.
Any synthetic oil will replace ANY "dino" oil w/o any problems what so ever.
Now, can you put 0W-20 synthetic where the manufacturer calls for 10W-40? No, I would not suggest that.
Typically, a good quality synthetic oil will FIX noisy lifters after a period of time, because (good) synthetic oils do an excellant job of cleaning varnish and deposits from the engine.
Old 05-21-2006, 04:40 PM
Banned
That is true story and synthetic will not fix noisy lifters all the time.Like my mother's 2006 Chrysler 300C,it call for 5w 20 motor oil only and it says on the oil cap and that is what is going in and NO synthetic.
Old 05-21-2006, 06:03 PM
unclebubbles unclebubbles is offline
About the only way you can get in trouble with synthetic oil, is putting it in a high mileage engine that has not had proper maintenence. Engines that havent had regular oil changes, or that have had cheap oil used in them, will tend to be full of sludge and carbon deposits. The detergents will start doing what theyre supposed to do, and clean the inside of the motor. If the motor has alot of carbon deposits, sludge, gum , and varnish, this can break loose and stop up the return holes in the heads, and the oil pump pickup screen. High detergent petroleum based oils can cause this also. Sounds like youve done regular maintenence, so you shouldnt have any problem.
Old 05-26-2006, 08:58 AM
Goose10202 Goose10202 is offline
Enthusiast
I am a dealer of Amsoil products and in my 20+ years using them I've not had any problems whatsoever. Yeah, I know that's easy to say but I also realize I was also once a spectic. I've used the oils in high mileage engines and new engines without having any negative experiences and neither have others I've known to use them. As for an engine with high mileage and poor maintenance, my own personal experience is, yes, the oil did clean the engine but where the engine initially consumed one quart per 500 miles the consumption dropped to nearly one quart per 1k miles. There have been other noticeable improvements beyond the reduced consumption including smoother idle, more power, better fuel economy and so on. In my newer engines, I've used the 0W-30 and have had no problems either and have put over 80k miles since. I also daily drive a 1995 Olds that has over 140k on it and it runs great. If you have any doubts and are using the Amsoil, you can also give them a call and talk to one of their techs who will be willing to help. I know most people bash the use of synthetics and like I said I used to be spectical about them but I did some research and also gave them a try knowing I could always switch back but in my case I've yet to find a benefit to switching back.
Old 05-26-2006, 08:52 PM
Goose, do you run AmsOil? If so do you run it for 35,000? I ran it once for about 17,000 and the urge to change the oil got the better of me.
Old 05-30-2006, 01:37 PM
Enthusiast
Yes, I run my oil within the specs they claim whether its 35k miles or one year and I change the oil filter ever 12.5k. It usually boils down to change the oil once a year and the filter in between. I know that many get skiddish about running it like they say but I'm not hearing of litigations against them and only once have I heard where they ended up replacing a motor.
Old 06-01-2006, 08:57 AM
Thanks Goose.
Old 02-25-2011, 08:39 AM
n2racing n2racing is offline
I have used Amsoil in my 99 Honda Accord V6 since 52,000. It now has 240,000 on it and runs like a dream. I have serviced it once a year or 25,000 miles. I had the pan off at last timing belt interval just for curiosity. Clean as a whistle. It still gets 27mpg and starts just like it should. I have never put a starter on it nor replaced transmission. It will still run 130mph also. Synthetics like Amsoil and Royal Purple are the best in my estimation. I build engines and have used it for years.
For Only Real Drivers
Old 02-28-2011, 03:49 PM
chamblizi chamblizi is offline
Yes Synthetic has been ran in a process longer then conventional oil once you choose synthetic you cant go back the good effect of synthetics is that its less sheers in it thus declining the ratio of wear and tear in your engines
-chamblizi
Owner Of Ford 1989 F-250 5.8L V8 Winsor
Hitting 400k Miles in about 2 weeks
Also Owner of 1987 Oldsmobile Cutlass Ciera SL
In restoration process has 75k miles
Old 02-28-2011, 10:23 PM
jyount jyount is offline
I cannot knock synthetics for the most part, they are a good product. They are engineered at the molecular level to have round molecules, not sharp edged ones. Can't argue with that, it makes sense. The only downside to any I have personally seen, not just hear say, is that when I worked at the GM dealer they recommended mobil one 5 30 in their 3.6 vvt v6s and most Caddy owners are a different breed and follow it religiously. Make no mistake it was a Cam bearing eater hard core, I'm talking like less than 100k! I worked on a man's jeep rubicon with the 4.0, he also ran 5 30. Had a miss that I took a bit to find, guess what it was, the number 2 intake lobe was worn flat on the cam. I won't talk bad about the others, but I WILL NOT use OR recommend mobil 1 products!
All that said, a quality dino oil is just fine. I have had a lot of engines apart, and I don't care if you use pennzoil, valvoline, quaker state, whatever, the deciding factor of any of the above is change your oil people. The most sludged up engines I have seen have been pennzoil, BUT it has also been the ones that change their oil every 10 or 20k weather it needs it or not, lol. The hands down way to longevity is keep it changed. You all can stretch out your synthetics if that is your poragative, may be fine I don't know. You better be ok as much as it cost! But I would HIGHLY recommend pulling a few oil samples along the way. A sample will show if it needs changed or not.
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
