Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 05-19-2006, 10:50 PM
HhowieE HhowieE is offline
90 Suburban Electrical
Truck shut down.
no power to fuse box..........shop gave up
WTF now??
Old 05-19-2006, 10:52 PM
TaNK_Em's Avatar
TaNK_Em TaNK_Em is offline
Send a message via AIM to TaNK_Em Send a message via MSN to TaNK_Em Send a message via Yahoo to TaNK_Em
Re: 90 Suburban Electrical
Need some more information here, what has happened?
- Kevin
May God have mercy upon my enemies, because I won't.
- General George Patton Jr
Old 05-19-2006, 10:53 PM
While driving, truck shut down.
Lights work, no dash lights or power with ignition on
Old 05-19-2006, 10:55 PM
TaNK_Em's Avatar
Ok, have you pulled the fuse block cover and looked to see if any fusible link has burned up?
- Kevin
Old 05-19-2006, 10:57 PM
Shop claims to have checked all fusable links.
They said there is no power coming to fuse box
Old 05-19-2006, 11:01 PM
TaNK_Em's Avatar
Hmm, Okay so you turn the key headlights will turn on no dash lights; I’m assuming the engine won’t turn over either? I have a 93 K1500 truck the ignition module went on it, the lights would turn on but the engine wouldn’t crank and the fusible link kept burning up. Not real good in this field but was the ignition module checked?
- Kevin
Old 05-19-2006, 11:03 PM
Thanx Man, appreciate I am not the best at describing the problem..
While driving there was a BEEP, which I thought was my phone and everything shut down. I coasted to stop, headlights, interior lights OK.
Nothing else works, GM dealer suggested Ignition short so the ignition was replaced to no avail.
Old 05-19-2006, 11:08 PM
TaNK_Em's Avatar
No problem, The beep maybe the buzzer in the vehicle acting like the keys were in the ignition but the engine not on. Same thing here my interior lights and headlights worked but when I turned the ignition one of the fusible links would burn up. So maybe it’s the ignition module or there’s a bad short somewhere. I’m not to sure there some other more knowledgeable people on here that might be able to help.
- Kevin
Old 05-19-2006, 11:12 PM
Cool..........thanx again for yer thoughts.
The guys at the shop are OK but, it is a Garage, not like a dealer with all the toys. I guess I gotta take it to be plugged in at the dealer.
I can't sell a truck that don't run..............!
Great site, glad I found yooze guys, I'll be back.
Mebbe I can help someone sometime.
Old 05-25-2006, 04:13 PM
Electrical problem solved, wiring to starter was damaged when tranny replaced 6 months ago. Required re-splicing.............$389.00CDN
