Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-19-2006, 05:46 PM
davevegas1 davevegas1 is offline
HELP (Please) 2000 isuzu rodeo, transmission
I think my transmission oil is low, due to a small leak on the shifter, i will get that fixed. but my question is where can i check it at, how do i add it, i was going to add some stop leak until i get to the garage next week, its a tiny leak, but will get fixed... my question is where do i add it at or how do i check the level or know if i have added enough trans fluid??? the only thing i see is 2 large bolts on the bottom of the trans pan bottom. and suggestions on adding and checking fluid and where to do that at... would be appreciated greatly ( by the way if you add it on the bottom by chance, how or what do you use to get it (UP) in teh transmission! you cant just pour it. many thanks!
Old 05-19-2006, 05:57 PM
marcre's Avatar
marcre marcre is offline
Send a message via AIM to marcre Send a message via MSN to marcre Send a message via Yahoo to marcre Send a message via Skype™ to marcre
Re: HELP (Please) 2000 isuzu rodeo, transmission
you need to buy a little pump and pump it into the fill hole. It is a pain to do. I would beg to come in earlier than next week, or find another shop.
2007 VW Jetta 2.5 5sp
1999 Rodeo LS 3.2 4x4 SOLD, but not forgotten
My Rodeo
Old 05-19-2006, 07:11 PM
Ramblin Fever Ramblin Fever is offline
When you get that leak on the shifter fixed, can you fill me in on cost and what they had to do?
I too have a very tiny tiny leak at the shifter, a few drops a week, nothing big, but was told that it wasn't an easy fix, with a comment also suggested that a transmission tear-down would be in order. Don't want to do that on a perfectly shifting auto until there's no choice.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 05-19-2006, 07:20 PM
where is teh fill hole and how do you tell if its low???
Old 05-19-2006, 07:44 PM
marcre's Avatar
there are two plugs(drain and fill). The higher up plug is the fill. You check it by opening it witht he vehicle running in nuetral. Open it up, if it drips out, it is fine. If it doesn't, you need more. Kind of a pain, that's why I let the pro's do mine.
This is all assuming it's the v6 auto.
marc
My Rodeo
Old 05-19-2006, 08:06 PM
surferfletch surferfletch is offline
I use a hand pump which screws on top of a quart bottle to get it up in there.
