Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 05-19-2006, 03:42 PM
ggratecc ggratecc is offline
2001 Spyder convertible top won't open
A friends Spyder convertible has a open/close switch on dash.
When toggling switch to "open" position nothing happens, no sound,
nothing.
What should I check first...fuse? Which fuse is it?
Is there a switch in the trunk to check?
TIA
Old 05-19-2006, 06:39 PM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Re: 2001 Spyder convertible top won't open
get your owners manual out and look under fuses...i know there is one for the top. If there is nothing happening it probably is a fuse....and if not that then a blown motor.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
