Old 05-19-2006, 01:53 PM
Mark Rudy Mark Rudy is offline
Smile 1966 ford f250 question
I have a friend who has a 1966 f250 with the 352 engine in it.... the main bolt that the power cable leads to is rusted loose off the base of her starter and I am looking to find a cheapo replacement starter fopr her out of a scrapyard. can someone assist in telling me what starters will fit? (ie: starters for 302, 351c, 351m, 351w, 390 etc)??
Old 05-19-2006, 02:49 PM
ModMech's Avatar
ModMech ModMech is offline
Re: 1966 ford f250 question
The BEST thing that you can do is to pull the starter out, and match it up.
Old 05-19-2006, 03:28 PM
unclebubbles unclebubbles is offline
Most of the starters for the 330, 352, 360, 390 should work.(361, 391 also) Some of the 6cyl starters would even work, by changing the end housing and armature. You could mix and match parts back then , and usually get something that would work. As mentioned above though, its best to take yours off to compare them. Be sure to check the distance from the mounting flange, to the end of the housing, and the number of teeth on the starter drive. There were some differences there. Even if you buy a rebuilt one, which arent that much, be sure to check it.
