Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 05-19-2006, 12:12 PM
ITSME4G63 ITSME4G63 is offline
Send a message via Yahoo to ITSME4G63
GT2860RS (disco potato) w/Tial 38mm
Approximate mileage on turbo is 30k, was on an Audi A4 and turbo is in great condition and pulled very hard until removed from the car. This is a dual ball bearing turbo with a T25/T28 flange so it should bolt to a stock sr20det manifold . The turbine outlet is a also a traditional garret style but I am including a 3" V-band adapter and used t-bolt clamp. The internal wastegate has been removed and the provision for the flapper rod has been welded shut and smoothed out. The turbo is set-up for an external gate and the gate passage is still open.
The turbo was purchased here (shown in top left picture): http://www.atpturbo.com/Merchant2/me...egory_Code=BCS
I am also including a Tial 38mm wastegate with a 17psi (1.2 bar) daul spring setup (yellow/green combo). The gate shows a couple light marks or scratches, works perfect and was used for less than 5k mi. DSMers can get a Victory Performance style o2 housing and use this gate with the passage open or it can be used on a manifold after welding the passage shut.
Asking price is $750 obo for everything.
Old 05-19-2006, 01:01 PM
nissan_240sx nissan_240sx is offline
Re: GT2860RS (disco potato) w/Tial 38mm
Wrong section. Try posting here http://www.automotiveforums.com/vbul...lay.php?f=1632
-Matt
NISMO
1992 240sx SE Fastback 5speed
Old 05-19-2006, 02:11 PM
slideways...'s Avatar
slideways... slideways... is offline
wow is every new t28 based ball bearing now being called a disco potato?
christ get the fuck out of here with your lack of knowledge
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 05-19-2006, 04:25 PM
Sold!
