Old 05-19-2006, 06:42 AM
alkemist's Avatar
alkemist alkemist is offline
Repressing struts?
I heard from a mechanic that if I take my old struts to a shop or auto store, they could repress them and I wouldnt have to by old ones.
If I was to do it, how much does this run for 2 front absorbers. How long is the life extended?
Old 05-20-2006, 08:07 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Repressing struts?
I suspect there is a bit of a miscommunication here. There is no such thing as repressing struts. Struts generally cannot be rebuilt or refurbished when they are worn.
What you can do is take your struts (with the old coil springs on them) to a shop. They can compress the springs and remove them from the old struts for you, then install them on new struts. In this way, you can re-use your old springs, rather than buy a whole new strut and spring assembly.
This works because usually springs outlast struts (often 2 or 3 struts, or more)
Old 05-21-2006, 01:11 AM
alkemist's Avatar
So if I understand correctly, auto parts stores, ie autozone carry struts with and w/o the springs in them?
Old 05-21-2006, 05:06 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Struts, in the most commom use of the term, are 3 main suspension parts combined together.
The shock absorber, the spring, and a suspension arm.
All are moving parts, the suspension arm however does not suffer any wear (although there are rubber bushs where it mounts to the car and wheel), the Spring does wear out, but it takes a very long time, and vey high millage, unless your car is over 20 years old its not worth worrying about.
The Shock Absorber however does wear out, and they will usualy be replaced once or twice in the average cars life time (there is one for each wheel).
Some shock absorbers can be rebuilt, usualy they are ones fitted in aftermarket performance applications.
When dealing with orginal equipment shock absorbers (factory fitted) its usualy cheaper to simply replace the unit with a new one.
When the shock absorber is part of a strut the strut needs to be removed, the spring compressed, the shock absorber removed from its centre, a new one fitted, and the whole strut refitted to the car.
Cost is very subjective, it depends where in the world you are, what sort of car you have, avliablity of parts, whether you want factory parts or aftermarket, how honest your mechanic is, ecnomic forces operating in your area, etc etc etc.
Its not an answer you are going to get on the internet, so you will need to get in your car and drive around a few mechanics and get some quotes.
Just make sure you get a quote to replace both sides at once, its very important to keep the cars suspension working as it was designed.
Any mechanic that is prepared to replace only one shock should be avoided.
