Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Maintenance
Maintenance Discussion about maintenance issues.
Old 05-19-2006, 04:51 AM
sky4ty sky4ty is offline
engine temp
does anyone know what the motor's operating temperature is for r33 rb25det??
Old 06-20-2006, 05:36 AM
Derby's Avatar
Derby Derby is offline
Send a message via MSN to Derby
Re: engine temp
The normalised engine operating temperature is between 85 and 93 degrees celcius (185 and 200 degrees fahrenheit) But that is a figure for all manufactures. It differs from one brands to another, but it won't be higher then 200 fahrenheit.
Derby
If there was one tiny little thing other then the rest, imagine the power it would have.
Old 06-20-2006, 12:12 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: engine temp
I have seen some as low as 160 and as high as 210, but Derby is correct, in that ballpark. Not the RB25, just engines in general.
My RB runs a lottle on the hot side, I would say 190, if I had to guess, comparing it to were other skylines I have been in.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 06-20-2006, 12:29 PM
Derby's Avatar
Re: engine temp
I know Mercedes tries to keep at 192.
And most of the manufactures set the max at 230.
That should help.
@SkylineUSA. A higher water tempurature ruins efficiency. I have seen test results for a engine that was kept at 1290 F and the efficiency was horrible because all the heat generated by the burning fuel was flowing back into the material around the flame (piston, cilwall)
Derby
Old 06-20-2006, 12:35 PM
SkylineUSA's Avatar
Re: engine temp
1290, That is a bit hot.
I can see there is a point were it will ruin efficiency. If I remember correcetly, the Older EFI Mustangs ran a little over 200f.
