Old 05-19-2006, 04:33 AM
countach79's Avatar
countach79 countach79 is offline
20yr old Countach 1/16
Hey all
I have just bought a Revell 1/16 Lamborghini Countach made in 1988 of ebay
I just test fitted the doors and they are grossly out of whack looks like they have been warped as has some of the body
Is there anyway of bending these parts to make them fit again?
Maybe heat it up?
Old 05-19-2006, 08:22 AM
73superduty's Avatar
73superduty 73superduty is offline
Lost in plastic
Re: 20yr old Countach 1/16
try shaping them under some hot tap water.
Chris
Old 05-19-2006, 10:17 AM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
If it's the same tooling as the Fujimi kit, the window glass helps a little after you carefully bend the frames back to shape. At least it helps it from remembering it was warped.
Also, if it is the same as the Fujimi tooling, check the engine height before final assembly, both of the ones I built when they were new made the engine cover stay open about 1/16th of an inch. An easy fix before mounting the body, not so easy after... - Mark
Old 05-19-2006, 12:36 PM
Vric's Avatar
Vric Vric is offline
I had the same problem with ma Fujimi F40 Ferrari.
Place the door on the body, tape it (so it take the good shape) and wait for few days. You can also apply the window to help you get the good shape.
Good luck.
Old 05-19-2006, 07:36 PM
countach79's Avatar
Thanks heaps!
I will give all your ideas a go
Old 05-30-2006, 03:57 AM
frugoman frugoman is offline
Hi, could you post some pictures of this kit? I had it years ago when I was a kid, and I've been searching the web for any info about it, but no luck so far... Is it the yellow lambo?
