Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 05-19-2006, 03:17 AM
matik07 matik07 is offline
87 camry how to remove steering wheel to relace combo switch
I need to change my indicator/wiper combo switch over (burnt out contacts)
I have sourced a relacement part but am unsure how to remove the steering wheel to change it over and anything I need to look out for.
Old 05-19-2006, 12:59 PM
somick's Avatar
somick somick is offline
Re: 87 camry how to remove steering wheel to relace combo switch
I am not familiar with this paticular model but as a rule of thumb you need a harmonic balancer puller or a similar tool. They are not very expensive. 15-20 dollars. If you have an air bag you MUST disconnect your battery. Look for screws that hold the signal and covers. When you remove them, you will see a nut that has to be removed and then using the puller remove the steering whell. Make sure you mark the position of it. Otherwise it may not be strait after you put everything back.
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 05-19-2006, 07:07 PM
Thanks Sam
Regards
Mati
