Go Back   Automotive Forums Car Chat > Toyota > Tercel
Old 05-18-2006, 09:22 PM
jamesmetairie jamesmetairie is offline
leaking oil=
anyone have leaking oil problems on a 1.5 ? it seems to be from the crank seal area. but it,s got a leak closer to the center also.the distributor has a little leak,but it ain,t too bad. the drain plug and the filter are not leaking.
Old 05-19-2006, 05:35 AM
gator2764 gator2764 is offline
Re: leaking oil=
You can change the O-ring on the dist. pretty eay. The oil pan gasket can be repalced as well. Might as well replace the valve cover gasket and rubber grommets while you are at it. Make sure to use a good valve cover gasket(felpro). The cam seal might be leaking a bit but it would be a pain to do that.
